Firmware 1.0.45 released
Also the language they use is a little ambiguous. Maybe this helps clarify things:
Shift and +/- will move all sequenced notes to the sample one semitone above/below the current note. It doesn’t affect any of the sample slices themselves.
thank you @jtswearingen :slight_smile:
so, I tried this and when I do this: All notes that are already sequenced will move by a semitone. e.g. the kick drum on the note G# will change to the snare drum on note A. But when I add new notes (e.g. G#), then they will have the “old” note.
Is this how it is intended? Because I don’t really see any use for this … maybe someone can let me know how they use this.
I really hoped that it would be the same as with changing the ocatave, so that you could sequenze “different” tunings for a drum sample. Because this is somehing I could really use ^^
Yep, you’re understanding the intended behavior correctly.
The use case (at least for me) is situations like “I want toms to play the hi hat rhythm for this pattern” and boom, transposing is easy. It might just make sense to me because that’s how it was on the OP-Z and it worked well with the way drums were given separate tracks on the Z.
For varying up the pitch, you could try to sequence notes from different octaves or use some of the Tonality/Ramp step components. Not sure if that’s the same as what you had in mind though. :slightly_smiling_face:
It seems that this update introduced a bug on the Punch-in FX.
For example the Mute, doesn’t work anymore, notes are playing at some interval randomly.
I was looking on the web and many are experiencing the same issue.
Hope that will be fixed soon, it’s totally messing live performances that need to use mutes and punch in fx at the same time.
It has been 5 months, has anybody figured that one out? I created a dedicated topic, chime in if you know, thanks.
