How to control/sync an external pedal (e.g. Chase Bliss)
I am investigating, what I should do to control/sync an external pedal from my OP-XY.
In particular, I have the Chase Bliss Lost + Found.
First of all, I would like to send clock from the OP-XY to the pedal, and if possible also parameter changes (PC/CC messages I think they’re called). Hopefully with just one MIDI cable.
I think it’s not possible to MIDI-connect the OP-XY directly to a Chase Bliss pedal, because these pedals use a different protocol (they get midi from the ring connection rather than from the tip).
For now, I found that I probably can use this MIDI controller/adapter:
If you have any ideas, of have tried any controller/pedal, let me know, thanks!
