Tried searching for others who’ve had this issue, and didn’t find any, so here goes:
r u using a third party CCK? or an apple brand one?
Using this one, from Apple: http://store.apple.com/us/product/MD821ZM/A/lightning-to-usb-camera-adapter
have you tried using it without ctrl mode? it still spits out, and responds to, MIDI while in OP-1 mode.
Wait, so you’ve tried it with combinations of what to connect to what first? Like this: with the OP-1 on, attach the usb cable followed by attaching the CCK, then plug it into your iPad. I think it needs to be in the order.
Did you try another USB cable?
So I did try it without CTRL mode after I posted yesterday. After some random sequence of events, involving switching the OP-1 mode, unplugging and re-plugging, I was able to get various iPad apps to at least detect the OP-1 - saw the “OP-1 Midi Device” listed under the list of MIDI inputs.
Yea me! I’ve been using the OP-1 with my iPad air since January. It was a little tricky at first, but once I got the right order of things connected, it worked every time. Currently I run the iPad Air with an iTrack Dock and I can record audio from Op-1 while also recording the midi notes.
I’m wondering if it’s OS update for either your OP-1 or iPad, although, my iOS 7 is an earlier version (jailbroken), it still recognizes the OP-1. You can try reformatting or reinstalling OP-1s OS if you haven’t already.
All the apps you’ve mentioned above should at least trigger sound from the Op-1s keys. I use Alchemy myself and the keys work automatically - it’s only when I want to modulate Alchemy, I then need to assign midi to whatever encoders on the Op-1 I want.
can you check with a camera and see if it works as expected there? I have never had problems with iPads and the OP-1.
the other thing to check is you are using the right midi channel for both… so if your app expect 10 in the case of a drums the OP-1 is set to 10 if you are doing any other synth they are usually set to 1 unless they are set to omni in which case 1 or 10 would work.
what app on the iPad are you trying to control?
…think you will need an Oplab or iconnectmidi etc.
@johnnyego, the CCK acts as a usb host, so there is no need for oplab, ICM, etc.
Kites - I know you’re using the iTrack now, but have you tried using the Lightning to USB camera connector before with your iPad Air?
dimi3 - have not had a chance to try a camera yet, but I will. Midi channels are lined up between apps and OP-1 out, both on channel 1.
Ya I use the CCK too. Have you tried using the OP-1 USB cable with a computer? If it’s not that then it comes down to the CCK.
Yeah, I’ve been able to use the OP-1 with the computer to back up sound files and such, no problems there. So weird!
Hmm, did updating to iOS 8 do anything?
Afraid not. Figure my next bet is to try getting a new Lightning to USB adapter from Apple.
Damn, that’s an odd one. Hopefully exchanging the CCK will help.
Any luck?
