I know when I reload the tracks to the OP-1 from PC backup, the slices that separate the loops on “tape” are retained.
When I load those tracks into LOGIC, however, there are no slices to indicate cuts in the original tape. Makes things harder to export, obliging me to re-edit and re-slice.
Any idea how I can load the tape tracks into a desktop DAW (Mac), and retain these slices?
The OP1 stores the slice information in a custom (edit: see below) data chunk at the end of the AIFF file of each tape track. As far as I know there is no code out there that processes these custom markers. I believe we’ve posted before on these data chunks, so it’s a question of someone sitting down and typing the code required…
@eesn said:
The OP1 stores the slice information in a custom data chunk at the end of the AIFF file of each tape track. As far as I know there is no code out there that processes these custom markers. I believe we’ve posted before on these data chunks, so it’s a question of someone sitting down and typing the code required…
That’s a shame.
Logic has a feature; just looked it up. “Import Marker From Audio File”.
I hope you’re wrong on this, and that TE used the standard protocol, and not a proprietary one.
good news: I was wrong, the data is in a ‘regn’ chunk at the end of aiff files. see this and this.
and bad: neither Logic Pro, nor Audition, nor Sound Studio read them on my machine.
Is there any way to do this? I use Ableton, but would love some way to import where my tape segments/slices are… Does the opfun site do something like this???
The consensus seems to be no.
Dayumn. Any workarounds?
I might start putting a 1 bar click before each new idea on my tape. This would make slicing old tapes later easier I think. Plus the @blezz tip of shouting ybr bpm into the tape during that bar. Combined = being kind to future self.
no idea how hard this would be,
but i bet someone could create a bridge
between the standard .aif protocol and the one the op1 uses for slices
i never looked but i bet all the info u would need is in the header of any tape track .aif file.
similar to how the drum sampler .aifs have the slice info in the header of the file
Fingers crossed that our tape slice saviour descends from on-high. ?
Whoever developed the tape backup on op1.fun has it figured out. Tape slices remain intact on the website GUI. I wish the developer would create a small-footprint app to import tape and allow export to individual wav files.
Ooh cool! So there’s hope. Yeah, it would be awesome to export tape aslices to individual files with some naming convention to make sense of lining them up… Or even select a certain section on the website. Begs the question why TE don’t do something with this, but don’t get me started. I won’t fall into a den of negativity. Op1 4 lyf
