My setup: Keystep Pro sends MIDI via Kenton USB MIDI Host to the OP1. After firmware upgrade to 243 OP1 doesn’t receive MIDI anymore. After downgrading to 242 (without changing anything else) everything works again. I tried sending MIDI over USB from my PC which works fine so I suppose that the OP1 somehow doesn’t understand the “translated” MIDI signal from the USB MIDI Host (MIDI DIN to USB to OP1).
Anyone else experiencing similar issues?
This is happening to me too. I use a Micro Ghost usb host and now it doesn’t work. Did you figure out a solution?
if i had to guess i’d say its something to do w/ the new usb audio feature thats maybe mucking it up?
essentially what is happening here but w/ the OPLAB & 243
No. Unfortunately not. Had to downgrade to the 242.
Any luck with this bug?
I wanted to connect the Op-1 to the midi host and the usb host to the midi in of my audio interface. That way I can sync a Po-33 using a Volca and record All three without losing the stereo on the Op-1.
All my other usb midi devices work just fine except for the Op-1
Just for the benefit of anyone else reading/experiencing this. Long time owner but new here, I can 100% confirm #243 stops ext sync with oplab (on latest FW). Back rev to #242 on OP-1 and ext sync between op-1 and oplab is back!! N.B After op-1 update I had to factory reset from the turn on while pressing com button menu.
Interesting, I have been experiencing a similar issue with my OP1 plugged into the USB host port on my Isla S2400. No external sync is possible over USB (even though clock is sent). After a while, the OP1 glitches out. I will revert to 242 and see if that works.
