cool, thanks y’all!
DMGs are soldered using lead solder, as mentioned use a higher heat to see if that makes it easier, I use a solder station and since buying one about 5 years ago my soldering got a lot easier, well worth investing if you do not already have one.
yeah I upgraded to a temperature controlled iron about a year ago and my soldering quality improved.
hey just wanted to say that i used some contact cleaner (deoxit) on a qtip
it works! internal clock in mod synced up to the op1.
@docshermsticks — that’s awesome man!
awesome! thanks for the detailed response
Has anyone tried the direct out mod on a gameboy color? I’m assuming NL Mono would sound just as good on a color or pocket as it would on a DMG if using the direct out mod, correct? Thanks
@psychickcv yea u are bypassing the gb amp and sound w/ the direct out. i don’t have another GB besides DMG but it should sound the same on any model.
i havent done it. waiting for a sale or something. a bit strapped with all the projects I got going on. plus holidays. Ill get one eventually hopefully during a sale. and will mod it with the direct out, sync, etc for my gameboy pocket.
Not sure it’ll this is the right thread, but 2xaa on Instagram has some nice work integrating nanoloop and op1
we dont have a Nanoloop thread. so this has sorta become the defacto! But everytime it gets bumped up I have to resist so hard not to order the nanoloop mono. Something about it I yearn for. Its like a tiny analog 4 octatrack. that instagram channel is awesome!
FUCK FUCK FUCK
Hmm, somehow I doubt it’d work. Depends on the attention to detail regarding full compatibility… if it has the audio pin enabled, then it may work… having said that though, nanoloop is a bit temperamental in general (for example, nl2.x doesn’t work on this awesome looking GBA clone).
Hey @Darenager is there any way you could share where you soldered to bypass in internal amp for this? Or anyone else who knows? Already have one DMG with RCA out but this would be nice also!
the answer is on page 4
D’oh! Thank you, I thought I had seen it but I keep checking and never saw it again for some reason. Thank you! Time to order a second DMG!
D'oh! Thank you, I thought I had seen it but I keep checking and never saw it again for some reason. Thank you! Time to order a second DMG!I can link two together for clock just with a standard gameboy cable? Or will I need to make a converter?
Yeah, the standard link cable works.
