its 256 MB (!) of ram / memory. not storage
So how much sample storage is there? 256mB RAM - OS?
They say over 160 min. Of sample storage.
This still isnāt a big amount relative to other devices, but itās 4x the RAM of the original OP-1, which is a meaningful improvement.
OGās sampler/tape format is 16bit/44.1khz/mono, and Field is 32bit/48khz?/stereo. Even if memory and storage increased 4x, the feel might still be the sameā¦
Price of aluminum really hit the packaging department this time.
5.7 GB internal memory!
Fact or dream?
Saw it confirmed on reddit
I wonder why they didnāt go with more ram. Hope thatās true about the internal storage but I do feel like dropping files easily via usb is imminent.
Or Bluetooth?
If the OP-Z canāt sequence the op1f synths/drums and record it on tape perfectly on beat match mode I will probably return the op1f. Iām surprised they didnāt add a new enhanced sequencer to the op1f for complex programming with control over velocity, retrig etc.
Has anyone here received the new op-1 field bag and tried to fit in the op-1 with the decksaver on?
Hey!
Iām the guy that did the unboxing video with the bag a few posts earlier.
The bag is tight but gets a bit wider with use. I tried to fit in the OP1f with the OG1 Decksaver,
but that is a really really tight fit. I gave up halfway through. It may be possible but takes a lot of force the first times⦠maybe that also gets better but i wont try ![]()
Toby
This will not fit. The field bag is to tight for that.
Damn⦠thatās a bummer⦠I feel sketchy bringing this thing around without the decksaver
This case can be used with the op-1 field, correct? And does anybody know if the decksaver fits in this one?
Definitely wonāt fit due to the power switch. Definitely not with DS.
I actually owned it and it was very tight even without the switch of the Field.
Edit: changed my response to definitely on both
on the shop, it says itās not compatible with op-1 field ā¦
