I’ve noticed a few things from a first glance
First of all they fixed the order of saved loops, so now the first loop you have saved is #1 and then it counts up, instead of the other way around like before
Also, they added a speed mode to loop playback. Previously, you could hold input to adjust the loop length. Now, input is designated to adjusting the speed, and you can hold input + play to adjust the loop length.
You can also use input + tape dial to quickly switch between saved loops.
Was hoping to see a way to be able to delete or export saved loops, maybe through the app, unfortunately I believe that wasn’t included here.
Thanks for this info. Really wish there would be an update to the OB-4 sample loop management.
I’d like to export, delete, re-order loops—maybe an update to the Orthoplay app?
HIya all. I was hoping you could answer a question I have regarding your OB-4 please;
when you have the volume down at the absolute minimum, can you hear any warble/ fluctuation/ sounds coming through? Mine does, on every damn mode, not just the radio.
@joey were you just notified in the app? I’m not seeing the update. Also, if you register, does TE send out software update emails when there is something new? I usually don’t “hang out” in the orthoplay app
