OB-4 + OR-1 functionality depends on the OR-1 firmware version. newer versions can control volume, track control and tape, previous versions can only do volume and track control.
there is currently no user-friendly way to update the OR-1.
hhmm, but how can you actually update the OR-1?
yes. .
sorry.
you do it by using a mobile app. more info in pm.
@JohnnyEgo : it’s not possible to send pm to you for some reason, it says “This user’s public profile is hidden.”.
a bit sketchy but really straight forward on IOS tho.
will try it with the ob 4
Ok. wow! the OR-1 can control the time stretching algo with a really fine control sheme.
are you people all referring to the actual -/+ tricks which are achieved with the volume pot or is there still a way to grab the TAPE labeled dial? ![]()
if you or others are still interested in updating your OR-1 to control the forward/rewind time stretch algo remotely, it’s quiet easy and I’ve been able to do so on iOS in a few minutes.
and I’ve noticed that it now shows a progress bar when rewinding or forwarding which is updating even if you leave the button while it’s rewinding
I’d love to try updating mine- currently away from my ortho remote for a bit but would very much appreciate the instructions for now
I tried to update my remote a couple of years ago and it was a disaster on my laptop. Would love to easily update it
with instructions from @jacobs
—check your pm ![]()
this worked flawlessly on iOS in a few minutes, just follow the instructions
to obtain the functionality when connected to the ob-4 is to press and hold the OR-1 (display shows speed)
this then gives control over the time stretch / disk rewinding automation.
if you’ve stored some loops the OR-1 will “reset” the loops when pressed down and controls the tape features as before.
the reset is great for manually syncing the loops to something else ![]()
you may discover more things ![]()
@JohnnyEgo Out of interest is there any reason you can’t just post the instructions here?
pm, please ![]()
@TrashTalk can you now just post it here?
@modulpaule I dont have the instructions. Not sure why @JohnnyEgo is being so secretive but that’s his/her choice I guess. ![]()
both, please send a pm.
iam just continuing the way TE told me and you’ll read it within the pm. just out of respect 🫡
@JohnnyEgo
The problem is that there does not seem to be a way to PM you - clicking on your forum name gives: This user’s public profile is hidden.
Is there some other way of initiating a PM without having access to your profile?
check your pms ![]()
