The first axis for this new battle is “soundtrack”:
MAKING MOVIES
Look for a video that inspires you (a trailer the sound of which you cut for instance). You can create it from scratch if you have the skills, or assemble* pieces of (ie copyright free) videos such as the ones bellow and make your own video! Don’t forget to cite your sources!
Here is a video I did to get you started:
All the source files are linked in the comments.
Feel free to rebuild your video from these bits or from scratch !
Here is a link to download the whole video above:
*Da Vinci Resolve is a free software that is pretty powerful to manipulate video and sound.
SOUND + VISION
Craft the basis for the soundtrack of your video. The aim is to get a “grid”, a basis that clearly gives you the moments when the video changes. You can either record yourself on the OP-1 while the video is playing, or go forensics and assemble (in Resolve or in a DAW) fragments of sounds to the video. You can even only use “markers” that would disappear in the final track.
Extract the audio and import this back into the OP-1. At least two OP-1 tracks should be left blanks. -
EXPLORE // MAKE NOISE
Prepare some sounds in the OP-1. An extra instrument (hardware or software) is accepted for sound design. Go as wild as you can, you can’t go too strange! In particular, you are encouraged to push the FX to their most uncomfortable zones, and mangle this as clay. Same goes for DNA and BBOX, two sound engines that are often disregarded for their awkward sound design or because they offer so much noise based sounds. Explore as far as you can, push the limits.
You can also sample your own voice and go crazy with this material. -
NO LOOP // NO BEAT (soft rule)
Avoid creating loops, at least no drum loops, unless it is somehow required by the movie (e.g. in a dancing scene). But even there, it is encouraged to use e.g. chords rather than drums. An occasional percussion is ok of course.
If you need inspiration, check Disasterpeace’s works or just pay attention to your favorite movie soundtrack…
The other aspect I would like to encourage in this battle is “transmission”.
Upload your track in SoundCloud with hashtag #OP-1Battle73 and submit it here.
You can of course also upload the whole video+soundtrack editing in YT and drop it here as well, if you believe it will give some interesting perspective for your track.
SHARE
When you submit your track, you should share a part (or all) of your sound design as samples, sample chain or user patches.
Do whatever you can so that other people can reuse your work. -
REUSE
You have to reuse at least one sound/patch/sample chain of a track that was previously dropped! It’s even better if you reuse a piece of each track that was previously dropped.
Make it not too long: target is around 3 minutes, could be shorter but not much longer (unless you have created an awesome short movie)
