tHIS!!!
wow
tHIS!!!
wow
did a lil digging.
the interface shows up as 2 in 2 out
and the output stereo panning does indeed work
but doesnât seem to matter what u do with the input
its always summed to mono.
i tried sending only to channel 1 or only 2.
tried panning with 1 or 2
tried sending pair 1/2 but panning left and right
tried monitoring on different screens
tape, drum synth, mixer, album, input select (mic)
tried recording straight to album (which is stereo)
then listening back via the usb output and headphones
always sums to mono. equal level to both L & R outputs
I just repacked 243 with all the mods enabled and everything seems to work just fine
Am I missing something obvious here⌠I want to use the OP1 as an audio interface with just an iPhone and multitrack OP1 sounds on the iPhone.
So I set tape to monitor USB input⌠great, this works I can hear the audio from iPhone coming through the OP1⌠now I want to play something on from the OP1 back to the iPhone as a new layer⌠problem is the audio coming in on the input of the OP1 is fed back to the iPhone⌠so I get a feedback loop
Is there a way around this? A way to monitor whats coming into the OP1 on the headphone output without sending it back out of the outputs over USB?
Thanks for this big heads up! I was worried about sacrificing all the nice things from the modded firmware in exchange for the new features.
Thanks for figuring this out.
So this means that although the OP-1 offers Stereo signal over USB, the OP-1âs input will always be a single channel input (mono).
I guess weâll have to settle for this. It is still amazing that we got this in the end!
I donât think youâll be able to do that. The USB I/O can be set as a source for one of the tracks, but the sound coming out of the OP-1 is whatever your âmixâ or final âproductionâ is. The OP-1 is essentially only one (stereo) source of audio at all times!
do we need to download specific drivers to get this working on windows? I saw someone do this on mac and it was pretty seamless⌠It wont show up under devices in ableton.
Anyone have any luck single-cable connecting the OP-1 & -Z with this USB interface opened up?
so i got the update and my input and output on my daw(logic) and mac are set to OP1.
I record something on the daw through op1 but i canât seem to hear the playback.
What am i doing wrong ?
Iâm interested in this as well and sent a question to TE support. My initial hunch says that itâs not possible because the OP-Z guide (18.2) says that the input device needs to be a USB Host which the OP-1 is not.
Not sure if this is a hardware or software limitation for either the OP-1 or OP-Z but crossing my fingers that itâll be possible some day. Iâm currently using an iRig to feed OP-1 audio into the OP-Z, but a single cable for clock sync + audio would be dope!
oh yes! thatâs what Iâve been wanting.
I always thought I had something set up wrong when this didnât happen.
Awesome! Wonder how useful that audio interface could be with iPad apps.
Works great on the iPad, though you will likely want another interface that also gets you a headphone jack. Audiobus 3 will let you route audio around, but it wants headphones plugged in to see additional audio interfaces.
For those not seeing input going to your OP-1, make sure you shift-mic and select usb as an input source.
Happy sampling friends!
I am running Windows 10 and Ableton 11. I have different hardware that has its own ASIO-based drivers, but I realized I didnât actually have ASIO4ALL installed as an option on this computer. OP-1 wouldnât show up as an audio option in Ableton, although (OP-1 Speakers) would show up as a generic speaker option under the Windows sound setting (didnât seem to have an effect on anything).
After installing the ASIO driver I can select ASIO4ALLv2 in Ableton. Selecting Hardware Setup in the audio settings opens the ASIO4ALL window where different devices can be turned on and off. OP-1 shows up on this list and can be turned at which point it will start acting as an interface.
I have been messing around with the settings for a while and I have been able to:
The last option was pretty glitchy no matter what I tried to do about latency. I recommend plugging headphones into the OP-1 jack and doing all audio monitoring from there. I have also had issues with audio feedback loops or audio doubling (I can hear the OP-1 regular synth plus a quieter version of that synth playing at the same time in Ableton with effects). The solutions to these issues have been to manually turn off the 2in or 2out options on the OP-1 driver depending on whether I am trying to send audio to Ableton or send it to the OP-1 (ASIO4ALL windows + Settings button + dropdown button next to OP-1 label).
It is functional, but it isnât super smooth and I keep running into audio issues like random crackling or delay. I have a very fast processor so I think this might be an OP-1 + Windows issues happening. That said, I have gotten clean audio out on both ends after a few attempts and I am having a lot of fun.
Hi all,
First impressions of 243:
For now, i went back to 242 so i can load in my old soundsâŚand yes, i did a factory reset first, then the firmware update.
Cheers,
It was already the case with sample based content, iirc.
Do you mean that there is some sound output from a regular synth engine patch ?
That would be interesting, it would mean they actually render the audio from the patch at some point when saving it.
Sorry Iâm a new owner, can someone explain the difference between the new tape arming and the old way?
Curious to optimise my workflow, hope its not too dumb a question!
this update is great, itâs a pleasure to use Koala and Model 15 digitally with the OP-1.
nice to blend in massive Synth sounds in line with the factory content or to use koala for resampling any tape track snippets with different fx a few times.
no significant audio loss, itâs awesome!
a raspberry pi makes a good audio host to mix or re-route all digital signals
You can arm tape recording by holding the record button. When pressing play or a piano key on the OP-1 it will start the tape and lock recording until you stop. This new feature allows you arm recording then automatically start the recording by pressing play on another device like a DAW or midi device that sends stop/start messages.
This makes it easier to sample in because before you had to time hitting record+play on OP-1 and play on in the DAW, in order to get your sample synced with the beat.
