What about transfering the album file to your computer. Then you select only the right/left channel output on the computer and record to let's say track 1 with the audio output of your computer feeding the OP1. Repeat for the other channel on track 2.
@ghostly606 Playing with the master faders should do the trick !!! Excellent suggestion, thatās what I was looking for I already play the Volca Sample live, I just cannot really do the panning trick both on the bass and the hi-hats⦠And playing twice live on two separate tracks does some pretty effects but not what I had in mind.
Hey Guys -this seems like a great idea with master L&R faders for album bounce to tape.Has anyone managed it and how do you avoid haas effect and keep timing locked between L & R on two separate tape tracks? Trigger start would be good if tape record is held then press play on album,but I donāt think this works.
This is pretty simple, but I didnāt see it mentioned & might be useful.
For pattern sequencer, if you are recording a few bars of your beat to the tape and you want that 4th bar to change, you arenāt limited to reversing the order of the pattern (though that can be cool & Maybe a lot easier to implementā¦)
What I like to do is grab the white knob & go hard left so the pattern length goes down to 1. So just the kick repeats for a mea sure , very common in hip hop.
Only drawback is itās pretty much impossible to 're-adjust the length so the pattern comes back on beat. Just have to cut copy paste it.
1. shift+mic button to change to the ear, then be careful of what master effects (and metronome) your using, just record all playing tracks to a selected track
2. press the key while moving a knob to change a value on the master mixer or fx, āmemorizeā will display, wait till itās red. when it is, that new position of the knob has been saved to the corresponding M-key
@iriebeats am i getting you right? ā Shift+CutTrackKey cuts all 4 tracks from the tape, then you can paste it back into the tape, and do so many times, so you can keep an unbounced version of it.
Itās no doubt been mentioned before, but for ultimate portability, the Kingston MobileLite Wireless G2 works perfectly with the OP-1 and allows you to back up your OP-1 to an SD Card or your iPhone / iPad (share your mixes to SoundCloud immediately using the AudioShare app!) and also allows you to copy samples / patches back to the OP-1 from the SD Card.
Itās a wicked little device that will now be accompanying my OP-1 everywhere!
earlier today i fiddled with my op-1 - especially the sketch sequencer since i barely used it- somehow i found out how to pitch bend apart from using shift and the arrow keys!
just go into the sketch page and while you hold a note on the keyboard move the orange knob to pitch bend. Not sure this has been mentioned before- I think its pretty cool!!
It's no doubt been mentioned before, but for ultimate portability, the Kingston MobileLite Wireless G2 works perfectly with the OP-1 and allows you to back up your OP-1 to an SD Card or your iPhone / iPad (share your mixes to SoundCloud immediately using the AudioShare app!) and also allows you to copy samples / patches back to the OP-1 from the SD Card.
It's a wicked little device that will now be accompanying my OP-1 everywhere!
This sounds awesome if I understand correctly. I install an App on my smartphone to control the Kingston, right? I can then hook my OP-1 up to the Kingston and basically file manage between flash media in the Kingston and the OP-1? File copying? Renaming of snapshots, etc? This could be a gamechanger for me.
Not sure if this is anything or not, or if itās maybe already common knowledge, but I was running the drum sampler with a sequence in endless mode, and realized I can sample into the patch somewhat live, with the sequencer changing over from the old samples to whatever I was feeding it AS it recorded⦠Was able to generate some interesting rhythmic material this way, and it felt like a sort of granular sampling technique, loosely adhering to the sequencers rhythmic settingsā¦
