Woah. Killer.
and realized I can sample into the patch somewhat live, with the sequencer changing over from the old samples to whatever I was feeding it AS it recorded...
speaking of which, I just fed the sampler, sequencer running, back into itself via the ear. it sort-of beat-repeats. tried with both drum and the sampler, drum is more fun. glitchy and kind of random after a while, but the textures are great. Iām guessing, since turning knobs isnt an option at that point, maybe midi lfo or accelerator could do it even crazier.
Yeah, I played with a few feedback scenarios, and ultimately it got pretty convoluted, thus my less than scientific reporting of the effects! Try just recording for a second or two, or less⦠Depending on the material, you MIGHT end up with some rastor-noton-esque rhythmic clicks/cutsā¦
Cool @scy1e, have to try this tonight. Thanks for sharing the tip!
I really like it when the user invent ways of using a device that was not imagined by the conceptor.
Hats off @scy1e
Nice find @scy1e
Thanks yall! Hope Ya put it to good use!
Oh, also, you can toggle between inputs as you do this, from line/mic, to radio, to ear⦠If you want to retain some of your samples w the ear, but add via radio/mic⦠Pretty messy stuff, maybe someone will figure out a way to use this less chaotically (I think that if you were sampling a rhythmic thing at the same tempo that your sequence is playing, you may get a bit more of a controlled sound⦠Have only been playin with semi-random noises so far stillā¦)
It's no doubt been mentioned before, but for ultimate portability, the Kingston MobileLite Wireless G2 works perfectly with the OP-1 and allows you to back up your OP-1 to an SD Card or your iPhone / iPad (share your mixes to SoundCloud immediately using the AudioShare app!) and also allows you to copy samples / patches back to the OP-1 from the SD Card.It's a wicked little device that will now be accompanying my OP-1 everywhere!
This sounds awesome if I understand correctly. I install an App on my smartphone to control the Kingston, right? I can then hook my OP-1 up to the Kingston and basically file manage between flash media in the Kingston and the OP-1? File copying? Renaming of snapshots, etc? This could be a gamechanger for me.
Hi @Ghostly606
Bought the Kingston Wireless G2 and it works with the OP-1 beautifully! Thanks for the tip @MrJoshua.
If only it worked perfectly with the Octatrack.... Such a shame.
Haha mine just got delivered! I was inspired by this thread as well. This is the thing that I've been needing, for several reasons, that I never even knew I needed.Bought the Kingston Wireless G2 and it works with the OP-1 beautifully!
Not sure if this is even possible, but has anyone figured out a way to import a drum kit .aif file with sample markers (probably not the right terminologyā¦) so that the OP-1 can create a patch nearly ready to go instead of having to manually set the sample start and end points?
I know this is pretty tricky stuff since the OP-1 uses itās own encoding in .aif files but perhaps someone figured something useful.
@cherrypulse, have you checked out the OP1 drum utility?
http://now.teenageengineering.com/post/47348903156/op-1-drum-utility
@Zzzach Wow, this is amazing, thanks a million. I donāt know why, I kept searching on Google for something like this and couldnāt find. Cheers
Has anyone actually used the drum utility with osx yosemite? I canāt get it to workā¦
@joeyfivecents Iām running Yosemity 10.10.4. No problem with Drum Utility. I got it from here https://www.xferrecords.com/freeware/index.html
@joeyfivecents I'm running Yosemity 10.10.4. No problem with Drum Utility. I got it from here https://www.xferrecords.com/freeware/index.html
How did you load your drum samples into it exactly?
What if a shot has a tail?
Iāve got some kits on the web and they are good ā¦but, sometimes I wonder about their precise nature.
I just drag short mono 16bit 44.1KHz was samples to the keys. Didnāt try with other formats. Never had any troubles.
is it possible to backup from the OP1 to an SD card that way ?!? That would be awesome !
Yep, I have an SD card in there all the time where I keep my OP-1 files. Connect, move / rename / copy files, disconnect, done.
