Any news on updates ppl?
nope
Iām gagging for new features to play with.
I wish more patterns + being able to edit effects parameters even when it is disabled
I emailed TE again with my list of feature ideas including the ones mentioned in this thread.
Not an overly interesting reply, but they are working on one.
Right now I REALLY Ć” want the release loop bug fixed and Iāll be happy!
But Iād die for a vocoder, better LFOs (2 at once) and pattern storage. Be even better to get some parameter locks and new effects and synths!
Dreamingā¦
Yes, pattern storage, there will never be enough
Playing drums and synth patterns at the same time would be great
Somehow, Iād want 3 POs in my OP-1 ^^
ā¦any news about update? ā¦and whatĀ“s about the user-presetsā¦itĀ“s nearly august!
Yeah I was thinking about this as well. Are there any spoken release date? Or do we assume that the release will be in august?
It will be released august 2014, like they promised.
It would be very clever of TE to implement the stereo split sync/audio design of the POs in the OP-1 OS. Best way would be the key press start feature also used in the OP-1 tape recorder. You could even rountrip through the POs back into the OP. I would like that very much (even if it means sacrificing panning).
Agreed.
using more internal memory for internal stuff would be the best thing.
The one feature Iād like the most is a basic one, a regular sequencer that will record what you play in and quantise it to the bpm, like practically every other hardware sequencer and DAW in the world currently does.
Thatās cheating though! Use the metronome and your fingers
Repair audio ,like in Soundforge -declick via interpolate or mixing in nearby copied audio.It works great 9 times out if 10.Occasional prob on transients.
This could be a shift and drop function.
Something as simple as normalization would be crazy handy.
What about a little USB-box as an update, that has the four tracks as separate channels out? and some other cool things i guess. PO-integration?
I would just be happy with the tape loop clicks fixed and the noise reduced some more on the headphone output.
