I have an RMA open with TE & am ready to send in my OP-1 Monday for repair, but I thought I would try one last ditch effort for advice before doing so.
Charging is recently erratic & the device no longer seems to properly hold a charge. The battery indicator when on (Help button) shows only 3 lit LEDs when the device is at "full charge". "Full charge" means that the device is plugged into a dependable power source & has completed the "charging animation". When attempting to charge the device I have to try plugging & unplugging, turning the device on & off, multiple times in different ways to get it to start charging, if it does at all.
Gone through the process of completely draining the battery twice in hopes of getting the battery & battery indicator to act normally again. No luck.
Furthermore, it's done some very strange things when plugged in & off. It's turned itself on, & in one case crashed after it turned itself on.
I've followed every step in the list of things TE suggested & it's still behaving erratically.
I'm also not able to get the thing to stick to a set of malfunctions. Before it wouldn't charge at all & was draining overnight when off. Now it seems to be charging, but the battery indicator is still messed up.
Honestly at a loss here. Never had any issues like this before, not even with the beta. I bought my OP-1 in 2012, new, from TE, & it's been the most dependable piece of kit I've ever owned. I love it, & don't want to part with it, even for repair. Makes me sad.
Image of crash when OP-1 turned itself on:
http://imgur.com/yPeT1D5
Image of OP-1 having turned itself on (power switch is in off position):
http://imgur.com/8KIXkW0
Seems like the battery might be gone. When you took the picture with the power switch off an the OP-1 running was it plugged into a charger or into a USB host device (e.g. Computer)?
