Op-xy & tx-6
I got a TX-6 in addition to my OP-XY, to be able to record directly on the TX-6, and add guitar tracks and voice tracks etc.
I was also hoping I could have a song on the OP-XY where each track (at least 6 tracks as there are 6 channels on the TX-6) can be controlled, be added FX, muted etc, directly from the tracks sliders on the TX-6. It turns out you can’t as hooking up TX-6 and OP-XY output to 1 channel on the TX-6 and separate tracks can’t be controlled from the TX-6, which is super disappointing as this is a basic use case and 2 products from TA could integrate natively much better.
I have seen a YT video where using a CME H4 MIDI WC for example, can achieve this, by basically remapping MIDI channels to convert MIDI channel 1 from the TX-6 to 6 different channels to the OP-XY: https://www.youtube.com/watch?v=v0yET0swkM8
Anyone here has done that before and would be able to explain in more details how to do it? I am rather lost indeed and I find that having the ability to do that would be good indeed, and again should really be a simple basic native function to link both devices.
Thanks!
That’s using the TX6 only as a midi controller - it’s not routing any audio from the XY to the TX6 in that video. So yes this would give you control over 6 channels of the XY but that’s a really expensive way of doing things.
What you have asked for is a very well requested feature for better integration but currently not possible and well documented that it’s not possible.
I suspect because so many have asked for it, TE won’t implement it because that’s the way they tend to roll.
You mean TE won’t implement what users need/want/request? Interesting way to do business and serve your customers :slight_smile:
I mean, if the more each product within the ecosystem interacts and embed with one another, the more likely someone who owns one of the products is likely to buy others quite logically;.
What would be a cheaper way to control the 6 channels for example?
Overall I have added the TX-6 recently, and I am trying to figure out how it can help what I want to do and I am not sure it actually can tbh
I was being somewhat cynical but only somewhat. For avoidance of doubt, I completely agree with you. Integrating the field system together better makes a lot of sense but with the exception of fairly good integration between the TX6 and TP7 they don’t really. I think the single USB on each device doesn’t help.
TE seem to deliberately do what they want and not what the customer wants - the lack of a simple undo on the OP1 is probably the best example of this. They could have quite easily implemented a (user configurable if necessary) undo button but they don’t. I think some people love them for this and others despise them. I don’t think TE actually cares at this point.
But to answer your question, re. a cheaper (than tx6) midi controller would achieve what is happening with that CME approach given it’s just using midi cc to control the XY - all the mixing is remaining in the XY
I wish music tech journalists could get past their obsession with TE prices long enough to ask this basic (obvious) question…why was usb integration left out?
It’s clearly deliberate if they had enough imagination and engineering skill to include it in the TX-TP pair, so why leave it out of the flagship OP devices?? I’m optimistic that they eventually cave to pressure but I’d like the answer regarding why it hasn’t been part of the vision for their field line so far
They mentioned in one of the recent super booth interviews that they have some updates coming for all devices that will make them work better together. Maybe we’ll get lucky and they add multi-channel streaming to more than just they TX-6?
I hope so but it baffles me why nobody in the synth blog world or press has asked them to go on record about their feelings. Seems weird but might just be a lack of imagination by the writers covering em
Fans have asked directly, the beta team used to test field gear must have considered it, and as seen by the OP here…it’s a normal expectation for new users that the machines connect intuitively.
Without hearing a direct answer I assume TE just thinks ble connection is the best way to link devices and didn’t think most people would care about audio routing between boxes
But with one usb port on each device how are they going to implement it in a meaningful way across each of the devices.
The TX6 and TP7 have very tight two way integration as of the new mixdown mode (and made even tighter by the addition of ability to record wheel, rocker as of yesterday).
But if you plugged the XY into the TX for example you can’t then record into the TP (or use the TX as a soundcard, or USB recorder) as the port is used.
That shouldn’t prevent them adding this functionality - but for them to get the WHOLE system talking to each other they need some kind up updated OP-Lab to plug it all into and integrate.
Yeah, single usb ports on all field machines are kinda frustrating but hub support has been integrated as a solution
I think TE envisioned ble as the ultimate means of integration but i’m not sure how that works with multiple boxes being used at once, an oplab style hub would be the ideal fix
TX-TP link has gotten deeper recently but basic transfer of 6 stereo tracks via usb was added 2 years ago
Something like that should already give us access to TX6 as an end of chain processor for 4 stereo tape tracks on OP1F or make it possible to record 4 stems on TP7
It would also be cool if the 8 tracks on XY were assignable to 6 stereo tracks on either TX or TP
Having said that there is much work to be done, 2 of the usb memory sticks I put in the TX-C are not recognised and getting a "no disk’ message. Impressive for a piece of gear of that price. Not.
Sorry to hear but many things can cause that. Did you format them correctly? What was TE’s response when you emailed tech support about the issue?
Seems odd that they wouldn’t be able to troubleshoot something like that for you
I have not contacted them about it as last time I did have a query it took them 5 days to answer ..that they did not know (and to be honest it was related to a complex connection with external gear they did not know about) - Both cards are formatted correctly, at least they work with no problem otherwise on all my other devices.
It might not be what you wanna hear but this problem can be solved pretty easily and TE aren’t really to blame IMHO
I understand that your past exchange with their support team soured your opinion of em. Without more detail there’s no way to know why your cards don’t work with TX6, but this is a standard feature that many other users have gotten to work as expected. If you’d rather not deal with TE then you can almost certainly get info from the community that will help solve this issue
Search here or on TE discord server when you have a chance. People have linked to various usb sticks that are compatible and you’ll have a chance to compare with what you’ve got
I have used a “compatible” usb stick actually and turns out it is not. My perhaps crazy expectations is that when I spend a little money on something it should work, perhaps foolishly so. Either way I appreciate you are trying to help and I take the point and will search here and elsewhere but let’s just say that for something as basic as a usb key I would expect a £1200 product to work (this is hardly a complex expectation).
Usb stick works perfect for recording and playing files.
Try harder.
That is a useful comment, thank you!
This USB drive has been working for me:
I can’t remember why I bought the split version (C and A) but anyway, it works for me with the TX-6.
Great thank you very much, this is helpful I appreciate it !
@Dom7364 I have been using this one:
and a lot of people seem to report using this make/model as well.
That said, I just want to say: you are not the only person experiencing issues with the USB functionality. I have had problems with stability when playing back recorded files on the tx-6. Files themselves are fine, and I could transfer them to laptop etc. but playing them on the tx-6 itself has been an issue for me in the past. After a couple of minutes playback would stutter and eventually stop. I reformatted the drive, and have not experienced the issue with the new update, but I also have not been recording as often recently so am not 100% sure if the problem is gone.
Again: am bringing this up mainly to say: as much as I love TE, and currently use 3 of their devices (bought my OG OP-1 the week it came out!) things don’t always work as easily or are as problem-free as one would expect from what I would call “high design” products. It can be frustrating at times, and requires persistence, attention and some curiosity and time investment from the user side, but to me, ultimately rewards are most of the time worth it. I come to these devices from the modular world, so the idea of constant flux is part of the environment, and perhaps my tolerance threshold is in a different place, but reality is: one has to assume that these are constantly “developing” devices, and what does not work now, might work in a week, either because we will figure out how to make it work, or it will be addressed as a problem from the manufacturer perspective.
Good luck with your setup, and I hope things get resolved soon!
