OP-XY Update 1.0.40 Now Available
New update for the OP-XY (1.0.40) is now available, here are the patch notes:
  • fix incorrect length of first recorded note when starting armed recording
  • prevent sequencer from retriggering already active drone notes
  • improved hub support
  • fix issue with saving snapshots after renaming the snapshot folder
  • fix MIDI clock lag over TRS MIDI
  • fix crash related to using CV track
  • fix rare crash when loading samples
  • fix crash caused by repeated project load requests via MIDI CC
https://teenage.engineering/downloads/op-xy
:smiley: I was coming to announce that
Thanks! Downloaded and installed.
Still bug fixing. Though it’s nice that TE works on fixes it is a high time for a big update to add missing/expected features, I think.
I don’t have a xy myself yet and I’m curios about which features is missing or expected?
You can check the OP-XY whishlist thread. Among many new ideas several essential features and annoying limitations are also listed.
First bug with this fw update… the wave form for the lfo in the midi ch track still remain the same (the sine) and i think also the rate doesn’t affect in the right mode
XY is incredibly complex as it is but it is even more promising as a platform. But some things are just off, like Brain does not affect CV track for no logical reason. There’s like a 100 of little things like that and then people want new devices & capabilities too.
I found a bug with the multisampler engine. On 1.0.40 for some presets with looping enabled, the loop is ignored and playback abruptly stops at the end of the sample.
To reproduce: On 1.0.40 load e.g. the factory patch “harmonium” and press C3 and keep it pressed. The sound will stop even though C3 is still pressed down. Expected behaviour: C3 plays the looped sample until the key is lifted and the release part of the envelope kicks in.
Note: On 1.0.38 this does not happen.
For now, I’ve reverted back to 1.0.38
Where should I report this bug to TE directly?
You can submit bug reports here: https://support.teenage.engineering/hc/en-us/requests/new.
Thanks!
Awaiting a stable release worth upgrading for…
I’m excited to get some new features.
