Op-xy wishlist
They just added more patterns per tack in their recent update. Now it’s 16 like the Z.
Hi everyone,
I went through the wishlist thread and tried to make an updated summary of the main OP–XY requests that still seem relevant after the latest OS updates, especially after removing items that have already been implemented or partially addressed.
This is not meant to replace anyone’s individual request, but rather to make the remaining wishlist easier to read and discuss. Please correct me if I missed something or if an item is already solved.
Main remaining wishlist items
1. USB audio, stems and export
This still seems to be one of the biggest requests:
  • Multitrack USB audio output to DAW
  • Separate outputs per track over USB
  • OP–XY → TX–6 multichannel USB integration
  • Stem export
  • Export/render of a song, scene, pattern or track to WAV/MP3
  • Better integration with TP–7 for shared transport, arrangement playhead, overdub and punch-in
  • Audio tracks that can run linearly with song mode, for vocals, guitar, resampling, etc.
  • A synced looper or basic audio track recorder
2. Drum sampler and drum workflow
The drum sampler still feels like an area where many users want more depth:
  • Mute individual drum sounds inside a kit, especially for live performance
  • MIDI/controller access to individual drum mutes or drum levels
  • Per-sample editing inside drum kits: envelope, filter, pitch, pan, LFO, EQ
  • Per-sample FX send or insert FX
  • Better control of release/tails per drum sound
  • Pitch automation per drum sound
  • Chromatic playing of individual drum samples
  • Mute groups
  • Layered or round-robin drum kits
  • A more complete drum sampler workflow, closer to dedicated drum machines/samplers
3. Sampling, slicing and time-stretch
Basic slicing has improved, but people still seem to want deeper sample editing:
  • Proper time-stretching
  • Pitch-stretch or pitch-scaling options
  • Offline/lo-fi time-stretch rendering to avoid high CPU load
  • Slice to bar / slice to 2 bars
  • Faster manual slicing, for example tap-to-slice
  • Permanent trim/destructive sample editing on the device
  • Rename samples directly on OP–XY
  • Zero-crossing detection
  • Better waveform/playhead feedback
  • Reverse playback when start point is after end point
  • Copy/paste samples between keys
  • Project archive including all used samples
  • Relink/search for missing samples or presets after moving files
4. Arranger, song mode and patterns
A lot has already improved here, but there are still recurring workflow requests:
  • Copy/paste notes, trigs or bars between patterns
  • Reorder patterns or clips freely
  • Insert/cut scenes in a linear arrangement
  • Separate chaining lanes, for example drums and melodic tracks chained independently
  • Bar/measure counter in song mode
  • Start playback from any bar/page in a song
  • Loop a scene for a chosen number of repeats, including infinite loop
  • Quantized scene/pattern changes for live use
  • MIDI control of scenes and patterns in arrange/song mode
  • CC for “next scene”
  • Step components for changing pattern, scene or song
  • Reset step counter to 0 at the beginning of a pattern, especially in song mode
  • Scene lock / pattern lock
  • Full track swap between two tracks
  • Delete unused patterns
  • Pattern reload / panic function
  • More than 120 notes/events per pattern
5. MIDI
MIDI has improved, but many users still seem to want a fuller implementation:
  • Full MIDI implementation / complete CC coverage
  • CC access to EQ, saturator, compressor, percussion/melodic levels, etc.
  • Active track MIDI channel controlling all track parameters, not only notes
  • CC access to M1–M4 pages or mode buttons
  • Custom labels for MIDI CCs
  • Labels in the MIDI device list
  • Map pitchbend to mod wheel on MIDI tracks
  • MIDI soft thru
  • Disable MIDI channel for the selected track
  • Keyboard splits for external MIDI tracks, with independent MIDI channels
  • One MIDI track controlling multiple external devices
  • Program changes via dedicated notes or easier workflows
  • Assign Maestro/modulation to external MIDI
  • Better MIDI control of scenes and patterns
6. LFO, modulation and automation
This is another big theme: people want OP–XY modulation to become more open and flexible.
  • Any LFO type to any destination
  • More modulation destinations: volume, pan, pitch, velocity, attack, ADSR, sample start, loop points, FX parameters, etc.
  • A second LFO per track
  • Ducking that does not consume the only LFO slot
  • Duck LFO available on AUX tracks
  • Better LFO rate curve
  • Slower synced LFO rates
  • Faster/audio-rate LFO options
  • Step-LFO or custom modulation shape designer
  • Loopable modulation envelopes
  • Pitch envelope
  • Envelope follower with multiple destinations
  • Modulation quantizer for pitch/OSC targets
  • Record parameter locks from the gyro/G-sensor
  • Control gyro-style variations with a knob instead of physically tilting the device
  • Better visualization of existing parameter locks on a step
  • Hear parameter changes while holding a note, without retriggering
7. FX, mixer and filters
A lot of requests are about routing, per-track treatment and more detailed sound shaping:
  • FX snapshots
  • FX presets
  • Save send FX settings with snapshots
  • Use send FX as insert FX
  • Insert FX per track
  • Insert FX per patch or per drum sample
  • Choose which tracks are affected by punch-in FX
  • Editable punch-in FX parameters
  • Better FX UI
  • Mixer view showing volume and FX sends more clearly
  • Master EQ with more bands, frequency and Q control
  • EQ per track
  • EQ per drum sound
  • Filter drive/saturation
  • Bandpass and notch filters
  • More filter/effect types: comb, phaser, flange, LPG, wavefolder, ring mod, frequency shifter, etc.
  • Pitch shifter / harmonizer
  • Grain FX
  • Spring reverb
  • Short self-oscillating delay
  • Transient designer
  • Amp sim / drive
  • Rotary speaker
  • Clipper with send amount per track
  • Multiband or spectral dynamics
8. New synth engines
The most requested engine ideas seem to be:
  • Drum synth / DBOX / Machinedrum-style engine
  • FM or TZFM engine
  • Vocal/speech synth
  • Custom wavetable engine
  • Granular engine
  • 101/303-style lead synth
  • SID/chiptune engine
  • Ring-mod synth
  • Complex oscillator engine
  • Physical/acoustic modeling engine
  • 8-bit / lower-clocked engines
  • More oscillator pages or deeper synth editing
  • More cross-modulation between engines or tracks
  • More exchange of engines between OP–XY and OP–1 Field, where possible
9. UI, file management and presets
Some file-management requests have already been addressed, but these still seem relevant:
  • Rename samples, presets and patches directly on the device
  • Overwrite an existing preset instead of always creating timestamped copies
  • Faster scrolling/jumping in long sample and preset lists
  • Better snapshot/preset workflow
  • Project/song names based on date/time or random name generation
  • Random default preset sets for new songs
  • Bluetooth keyboard support for naming
  • Bluetooth file transfer
  • Desktop app for building multisamples and drum kits by drag and drop
  • Bigger text/numbers on screen
  • Track numbers in arrange/mixer views
  • Track icons
  • Scene/pattern names shown more clearly
  • Color/shading for song sections like intro, chorus, break, drop
  • Better use of LEDs for step components and track states
  • Clear indication of when the selected track is about to loop
  • Remember last subpage when switching tracks
  • Stay on player page when changing tracks
  • Press+turn shortcuts for faster navigation
  • One-tap metronome on/off
  • Global preferences, including metronome default state
10. Live performance and stability
Finally, some broad but important requests:
  • One-handed track mute/unmute
  • Dedicated live/mute mode
  • Track LEDs showing rhythmic activity
  • Assignable performance macros
  • Synced loop recorder
  • DJ/live-loop style performance mode
  • More live-friendly song mode
  • Manual jump between scenes while in song mode
  • Punch-in FX while still being able to mute tracks/drums easily
  • Better visual structure for live sets
  • Continued bug fixes and performance improvements
  • Faster loading and smoother overall OS behavior
  • More robust MIDI, MTP, sample and preset handling
Again, this is just a community summary. Please add, correct or merge anything I missed.
Thank you :folded_hands: I made an entire album with an OP-XY - but sold it because feeling like it’s an unfinished machine. I will get an other one for sure if they improve it with THE update we are all waiting for. Peace. Love. Unity. :growing_heart: :peace_symbol: Zach
awesome list thank you for compiling! Had a couple questions about a few that might be possible aalready?
Hold sample key down, then COPY, then on the new sample hold it down, PASTE
Not a knob but i think you can control gyro stuff via the pitch wheel too? Maybe not for LFOs, but for punch in FX i know it works.
I think this was added in the last firmware(s)
This was added in the latest firmwares (Random Template)
RE: Project archive including all used samples
I just built this tool that can do a full birds eye view of your project (requires copying it to a computer first): https://opxy.app - let me know if theres anything you want to see in this app, happy to try and implement it!
my list to Teenage Engeneering.
1. Record position
  • Issue: Live recording currently always starts from the beginning of BAR1 in the pattern.
  • Idea: You can already set the start point for step recording by holding REC + Step. It would be great if this custom position was maintained for all other record modes, and even during playback. To reset the start position to the beginning, you could double-tap STOP (perhaps showing a red “1” to indicate it is reset).
  • Bar selection: To set the start point on another BAR, you could simply hold REC + change BAR + select STEP (similar to how step recording works today).
2. Chord Editing
  • Issue: Adding new notes to an existing chord currently deletes the existing notes first (unless you use the workaround of double-pressing the existing notes before editing).
  • Idea: When a step contains more than one note, changing notes should function as a toggle (on/off). Steps with only a single note can keep the current behavior.
3. Chord Changes Over Octave Ranges
  • Issue: It is currently not possible to add new notes on a different octave.
  • Idea: With the toggle fix mentioned above, you could move the Nudge function to Hold Step + SHIFT + plus/minus. This would free up the standard interface to allow octave changes while holding a step.
4. Clear Step Components
  • Issue: There is currently no way to delete only the step components on a pattern.
  • Idea: Press BAR and use the unassigned M3 encoder to trigger a “clr step components” command.
5. New System Parameter: LED Dim Level
  • Idea: Add a new system parameter to adjust the LED dim levels. Right now, it can be difficult to visually distinguish if an LED is dimmed or completely off.
6. New Project Parameter: Track LED Activity
  • Idea: An option to make a track’s LED light up (or blink softly) whenever it plays a note. The selected track would still stay fully lit, while others dim. This would make it much easier and visually engaging to see which tracks are active without having to switch to the mixer page.
7. Mixer Page Effect Levels
  • Issue: You cannot see the send effect levels on the mixer page.
  • Idea: Use SHIFT + MIXER to display an overview of all effect levels.
Time to dream: More M-Pages
  • Issue: Having only four M-pages per channel (M1–M4) limits the number of parameters we can control. Additionally, M-keys are used to turn the Filter and LFO on/off.
  • Idea: Change the on/off toggle for the Filter and LFO to a 1-second long-press on the M-keys. This would open up the M-keys to handle multiple sub-pages. Pressing an M-key would cycle through its sub-pages. Pressing a different M-key would reset the cycle back to page 1.
Example of sub-page structure:
  • Synth Page 1: Current behavior.
  • Synth Page 2: Deeper parameters for each engine (e.g., pitch-shift and time-stretch parameters for the sample engine). Moving the current M-key + SHIFT pages into this sub-page structure would also feel much cleaner.
  • ADSR Page 1: Current behavior.
  • ADSR Page 2: A second ADSR envelope that can modulate any synth or LFO parameter. Turn Knob 1 to select the modulation source, and Knob 2 to set the modulation depth.
  • Filter Page 1: Current behavior.
  • Filter Page 2: Channel EQ.
  • Filter Page 3: Channel FX sends (similar to a standard effect track layout, using SHIFT to select the effect type—even just having Reverb would be a massive upgrade).
  • LFO Page 1: Current behavior.
  • LFO Page 2: A second LFO that operates like LFO 1, but can also modulate parameters on LFO 1.
(This sub-page workflow would also open up massive possibilities for all auxiliary tracks.)
Advanced Note Editing Mode
  • Issue: When multiple notes share a single step, you cannot edit their data individually.
  • Idea: Hold a Step + SHIFT to enter a dedicated Advanced Edit Mode.
    • The screen/LEDs could show the same overview layout as the BAR key.
    • All notes in the selected step will start flashing. Pressing a note toggles it between flashing (selected) and solid light (unselected).
    • All flashing notes can then be edited simultaneously using the following controls:
      • Length: Hold Step + hold Length Step (standard behavior).
      • Nudge: SHIFT + plus/minus.
      • Knob 1: Pitch (click/hold knob to jump by octaves).
      • Knob 2: Micro-position (quantized by default; click the knob to toggle grid snap on/off).
      • Knob 3: Velocity level.
    • If there are multiple notes in a step but they sit at different micro-positions, use + / - to navigate between the positions.
    • To edit a different step without leaving the menu, simply press the new step.
    • Press M1 to exit Edit Mode.
Additional Wishes & Questions
  • Gate: Add a Gate effect to the Players menu. It could include classic beat-gate patterns, or even allow us to select a specific track as a sidechain/control source to trigger the gate.
  • Multi-level Undo/Redo: Add multi-level undo, and introduce a Redo function mapped to SHIFT + hold REC.
  • Multi-USB Output: Expand USB audio capabilities to support multiple discrete outputs.
  • Punch-In Effects: Double the number of available punch-in effects by utilizing a SHIFT modifier layer.
  • More Effects & Synth Engines.
  • A quick question: Why are there LFO options visible on the Brain, Punch-In, CV, and Tape tracks when they don’t seem to have any effect? Is this a bug or a feature coming in a future firmware update?
Long lists with lots of wishes. I’m a bit more modest :laughing:.
  • Locking option for editing single drum lanes w/o holding multiple buttons at once
  • Option to start resampling with the play button (instead of threshold)
  • Locking option for solo track
  • If any input is enabled, this should be memorized within the project
When it comes to larger features, I’m most interested in a completely revamped drum sampler.
This! Note editing. Being able to focus on a single note lane to nudge, edit length and velocity - that’s the minimum.
Saw this was fixed in EP-133.
fix: choppy USB audio when streaming from android devices (e.g. Pixel 9).
Please fix this also for OP-XY :folded_hands:
I’m starting to make my OPXY the center of my live set up. A feature I wish for that I’m not sure anyone has suggested yet would be the ability to loop a pattern within song mode. I specifically wish for this so I can riff on a pattern live for as long as I want. When I’m done improvising I can go back to playing the song where I left off.
Currently if you wish to loop a pattern you have to exit song mode and select the pattern. The problem is when you try to go back to the song mode it starts from the beginning of the song. You have to quickly navigate through the scenes of the song with the cue feature to get to wherever you wish to go before the current scene finishes.
I suggest there be an added option with the loop song knob. If you toggle it once more it’ll loop whichever pattern you are currently on within the song. It could have a small 1 symbol in the top corner of the loop symbol. You can easily toggle it off by twisting the knob once more, thus continuing the song.
Hope that makes sense and happy to clarify if it doesn’t.
That makes sense, and I’d love to see something like this too. For live use, “hold here until I say otherwise” is such a natural performance need, especially if the OP-XY is acting as the brain of the setup.
Your suggested extra loop state on the song loop knob feels pretty elegant because it doesn’t require leaving song mode or breaking the current flow. Ideally it would keep the song position armed in the background, so when you disable the pattern loop it continues to the next scene/pattern as if you had just extended that section live. That would make song mode much more playable rather than just linear playback.
Over 10,000 views on one subject. TE, are you listening?? USB SEPARATE TRACK AUDIO PLEASE. i know you can do it cause OP 1 just got it. PLEASE! you guys were great to me. you accepted 2 units that were faulty and sent me a brand new one. THANK YOU. And i love and depend on my OP XY as my main writing tool. However i use Ableton LIVE and an Akai 3 Live as my other writing tools and it would be GREAT not to lose my creative flow by not having to always solve technical issues. Thanks in advance..(but soon please!)
I want whatever all of this is
The future of electronic composer instruments is going to be competitive. At €2.2k, it’s hard to stand your ground when devices like the Move, Schwing, TBX16, and others are lining up. Some of those platforms are open source too, which raises an interesting question: could a TE UI box/shell with enough CPU power to host community-developed code become a viable direction? Heck, even a TE-style shell for the M8 Headless with proper controls, keys, knobs, touch input, or an improved OP-Z-style disk would be pretty exciting. :waving_hand:
The M8 is a great example of what strong fundamentals can achieve. Between its clean audio path, excellent synth engines, audio-rate modulation, and filter character, it sounds phenomenal. What it lacks, in my view, is real-time time-stretching, formant shaping, phase modulation between samples, and perhaps most importantly, playability. The M8 is an incredible tracker, but a tracker is still a tracker — and I don’t really think of a fax machine as a musical instrument. :face_blowing_a_kiss:
What truly sets the M8 apart are its mod lines. These independent modulation sequences can run alongside tracks, have their own lengths and resolutions, contain notes and step FX, and directly influence the main sequence. It’s almost modular in spirit and easily one of the most powerful sequencing concepts I’ve seen in a portable instrument. If I had one wish for the Y, it would be MOD LINES. Even a simplified implementation would open up a huge amount of creative potential.
I’m a fan of the Y and can see it steadily improving with each OS update. But at this price point, I think deeper synthesis, modular-style routing, real-time time-stretching, and formant shaping are becoming increasingly important as the market evolves. So my question is: how difficult is it really to push the platform further in that direction? With a quad-core CPU under the hood and AI reportedly accelerating development, are features like modular signal routing and mod lines as far-fetched as they once seemed? :thinking:
even a simple updated version of th OP Z’s ipad interface would be such an improvement. im sure someone can hack the old one and connect it to the XY
Release Trigger / Note-Off Samples
Truncate Sample
Time Stretch
That would make me happy :slight_smile:
all i want is the ability to ‘focus’ on a specific bar (ie not having to play and record from bar 1 every time i want to make a change)
Yeah that’s super annoying. I rarely use bars because of that. I’ll use different scenes.
Not familiar with M8 for synthesis and arranging. Just got the ios app but none of my friends with M8 have said anything about em before
Can you explain the difference between mod lines and lfo’s? Are there a limited number of them?
1st: There are more relevant feature requests here, the last three posts suggested vital ones
Release Trigger / Note-Off Samples, Truncate Sample, Time Stretch, Loop a Bar with a Pattern, Sustain a Step in the Arranger, and Color Tagging / Scene Labels (Intro, Groove 1, Chorus, etc.) would all have a much bigger impact.
I meant to say if there was one wish in this post .. not like this is nr:1 Not a must have but… :wink: being able to repurpose an unused track or AUX Track (CV/MIDI) for modulation duties could enable some very powerful tabel like workflow ( what I refered to as mod-lines) Likewise, Step-Locking the Arpeggiator could serve as a programmable Step FX system, and the Tape Machine already touches on some of this territory.
M8 tabels (not modlines) feature independent tracks running alongside a main track that can apply Step FX, indy resolution, step jumps, tempo shifts, and other offsets that are kinda its superpower. A hack that comes to mind is hooking XY MIDI out back IN and using the MIDI track to add tabel like controll to a synth track (?)
TBH, after thinking about it, I’ll probably end up with the XY. It’s a bit of a dream machine for me.
And honestly, I wouldn’t be surprised if TE eventually released an iPad app as an homage to the original Z—something with a full visual arranger mode, more like a proper DAW. That would be absolutely stellar. :sparkles:
Improved/ More Synth Engines ( Even if engines from the Field were brought over )
More options for effects per track/ per sound
Multi USB Audio / Export Stems
Another LFO per track
Improved Sample Management
