i want to share this app with you. because its impossible to live with out it.
literally almost evrything is possible with it. if you have any MiDi gear than you can get crazy functionality out of it.
you can control a lot of things simply with your keyboard or anything else you might have
all presets are here:
harmonic# scale
pentatonic scale
play stop - mod wheel
pattern change - pitch band
mute group select - mod-wheel
you can use those presets more like an inspiration templet and change things in it how ever you like.
@onthervn im sending syntax with MiDiFlow. (if C4 is pressed syntax … is sent)
@nok @xmacex thats for kind words. i apreciate it a lot ![]()
