I never saw a cable like that but usually i use a lot of adapters from cinch to jack to minijack. I hope there is an all in one cable like that
Trs minijack on one side and on the other side two times ts minijack.
After a quick look, this looks like it would work
Hosa YMM-261 3.5 mm TRS to Dual 3.5 mm TSF Stereo Breakout Cable
[edit]Or this one, if you want to “cable all the way” to your modular (note, these J&D cables are great with the OP-Z as they are not fatter than the OP-Z so it sits flat on the desk):
J&D Gold Plated [Copper Shell] [Heavy Duty] 3.5mm 1/8" TRS Male to 2 X 3.5mm 1/8" TS Male Stereo Audio Adapter Cable - 9 Feet
Yes. Thanks. That could work. Until now i only found stereoo splitters that had two times the same signal on the other end, these look like they have left and right split. I hope they sell them in europe hosa is from the us .
Edit. They send to europe
now i want one for the op-1 as well.
Goodby to my adapter tower thingie.
i just took like 5 minutes to google it and found a couple more
and
should‘ve been 59,- € at least. especially this one should state a standard range of connections as I think everyone should get this module…
it’s really pricey by now.
the Original has been really pricey aswell but there was nothing to compare at the time of release + really really low stock worldwide!
i have to see the other modules but now it‘s meh
Yes thanks. In the us they are easy obtainable. In europe its harder.
Until now i only found the cinch ones
This one seems ok
But i already have two of these but they just make two stereo out of one stereo.
Its cheap so ill try it again.
Another stupid choice besides the price tag is that we only get either midi out or po sync from the module.
Thanks for posting the guide. Interestingly, the guide says the midi cable is included but on the order site they were selling it for $20…?
Yes, I believe 1 is included. Additional are $12USD. You may need extras if you want MIDI out as well as in for example.
It’s sold out?? Wtf I need this… Damn…
Id say more than just a couple plugs too haha!
Could anyone clarify what I’d be gaining with the module when connecting the po 33 (or any pocket operator) to the opz (which I understand is already feasible without the module). Does this add the sequencing capabilities of the opz to the sounds from the pocket operator?
no it doesn’t add sequencing capabilities…all it does is that it let’s you use the OP-Z in stereo, whereas the hack version makes it mono.
But ifyou are using a Retrokits RK-005 or something similar it is not worth getting this overpriced module. IMHO
Yes, if you only need the MIDI / Sync part and don’t mind an external solution:
It’s way more flexible than the module for approx. the same bucks.
If you use a Keystep with your OP-Z you already get midi, CV, plus arps and a keyboard.
I think the RK-005 also does CV/Gate…so you probably get the same funtionality for less money
when the next module comes out, you can use the RK-005 while using a new module…
That’s what seems especially stupid about these modules. But who am I to judge the cashgrabbers
RK-005’s CV capabilities are very restricted (no voltages beyond 3.3V, and one port only). If you’re planning to use the OP-Z with a modular rig (e.g. the PO Modulars) the ZM-1 module makes perfect sense, and I’d buy it in an instant. But since I’d only use MIDI and sync at the moment, I’ve opted for the RK-005.
I agree. My go around is to use an Arturia Keystep… you can connect via USB to the OPZ and pass midi through via the Arturia midi inputs. Haven’t tried the cv gates, but this option is a similar price… If there is a sampler module than this will be redundant as well.
That’s true, but it’s nice being able to just have the opz and not need anything else, plus you have the settings inside it instead of having to program the settings on a keystep. When the sampling module comes out you put it in when you go out and sample stuff and put the oplab in once you got your samples in… that’s not that bad I don’t think, that way you get all the functions all the in and out control and still get a small size. I’m glad I got the module but there are other ways.
