OP-Z Tips and Tricks
oh wow ok that is reassuring to hear and also that info there is super helpful!
Thats the soma Pipe, vocal transformer/mic.
One more crucial detail/tip about Punch-in FX: the loop effects (G, A) don’t loop the last note played by the sequencer, but the last note you triggered.
For example, if you only have hi hats sequenced on track 3 but you play a tom, Shift + G/A will trigger a tom roll.
wow did not know this. thanks a ton
When shifting sequence notes on the OP-Z by holding Track and pressing Left or Right, I like to add a Step Component to the first step as a visual reference for the sequence’s starting position. I usually choose Component Spark. After shifting steps, the component shows me how many steps I’ve moved without counting, and helps me return to the original position if needed.
I find it most useful when the sequence is playing, letting you go crazy shifting all steps while still being able to quickly get back.
It’s not an amazing tip, but maybe some people will find it helpful.
I recently discovered a feature that makes the OP-Z arpeggiator track even more awesome: step components and pattern length can affect the order or duration of the notes. The behavior is quite quirky and I can’t quite figure out the logic behind it yet, but I’ve had some interesting results with pulse hold and multiply to change the rhythm, velocity for accents, and changing the pattern length for various note repeats. Some of this can also be done with parameter locks, but I find step components easier to edit and move around. Unfortunately jumping to a specific step doesn’t change the order of the notes.
What I really love is that this also works when playing live notes, as long as the sequencer is playing!
Something some OP-Z users might not realize: I love how it allows a couple of seconds for you to press that last button when entering the BPM manually. For example, if I want to change it to 89, I can press 8, wait a couple of seconds, then press 9—and it switches right when I hit the 9. Or for 120, I press 1, then 2, and can wait a bit before pressing 0. This is great when you want to change the BPM precisely on the beat, whether you’re switching to a different pattern chain, or just adjusting the tempo on the current one.
to my surprise I discovered that pressing pattern button 3 times makes that button to “Stick” so you can change patterns without holding the pattern button. Same is with Mixer button, press 3 times and you no longer need to hold it to mute/unmute tracks.
