•• OP-Z TRRS Splitter I/O ••
MEMENTO DELUXE back once again
@ https://digdugDIY.etsy.com
https://digdugDIY.etsy.com ===
• MEMENTO DELUXE
fka OP-Z TRRS SPLIT I/O
TRRS I/O AUDIO INTERFACE (SPLITTER)
& 2 CHANNEL PASSIVE INPUT MIXER
plus OUTPUT EXPANDER
2x 1/4" TS outputs = separate LEFT and RIGHT stereo output jacks (BACK)
great for separating sounds // tracks for further processing
with the panning function
for Teenage Engineering OP-Z & OP-1 Field, TX6, TP7 & OPXY
(and MANY other devices with TRRS Combo Jack)
splits TRRS Jack into separate INPUT & OUTPUT Jacks
for easy sampling, monitoring and mixing external sources
both INPUTS can be used simultaneously
both OUTPUTS can also be used simultaneously
MEMENTO DELUXE
• MEMENTO DELUXE
back in stock one more time
@ digdugDIY.etsy.com
back again
back again with something a lil different
OPZ TRRS I/O FX SUPREME
AUDIO INTERFACE & SPLITTER
with 12-BIT AD/DA INPUT FX
& OG Tapedeck [stereo] OUTPUT FX
& OUTPUT EXPANSION
with additional INPUT & OUTPUT FX Modules
for added colour vibe and character
heavy on the aesthetic
INPUT EFFECTS = 12BIT AD/DA Converters
variable sample rate from 1.87 kHz to 32 kHz
variable input gain
OUTPUT EFFECTS = OG Tapedeck [stereo]
all analog studio console based
saturation & Hi/Lo 2x Band EQ
recording preamp // postamp // equalizer
back once again
@ https://digdugDIY.etsy.com/
I still kick myself for not grabbing the OP-Z FX Supreme while I had the chance :smiley:
great device with a lot of functionality regardless if they are in this or the pedal format… if you’ve got a TRRS jack… such os OP-Z, iPhone, OP-1 Field, P-6… etc… can open up some additional possibilities for fx/mixing/converting mic level to line level…
i’ll prolly make another FX SUPREME at some point
and yea i agree there are lots of devices now that can use this
i mainly use mine on my ipad for easy audio in out
tbh i’m surprised i am still making these
ppl keep asking me for them so i keep them going
