I got them for the field and my op-z. They are sick and perfect!
no dead animal skin necessary. Just because your device costs a lot of bucks, it doesn’t mean you need to spend extra on some ill-fitting branded bag. There’s nothing I love more than finding just the right unbranded bag for my new gizmo. But hey, whatever works (or looks best on instagram).
Which pattern are these? The seller’s Etsy site asks you to select from three options but they don’t show you what they look like. Really want to order one. Thanks!
Also works perfect with a DeckSaver
Shit sorry man for this late replay. I’m not sure. The seller custom made them for me. I was like a tester for the covers. Ask him via chat. He is able to help you out!
Update: it is most likely the “standard pattern”. It has the pattern up front and the logo on the back ![]()
Hey, I found your post since you mentioned Bellroy - I was looking at their 6L venture sling, I can see you have the 9L. Do you think the OP-1f would fit in the 6L? Can’t find good interior dimension specs for the 6L.
Hi, i doubt it would fit in the 6L sling as my OG and Field OP-1 fits in the 9L a bit slanted diagonally. There’s enough room in the 9L but quite sure it wouldn’t work with the 6L. I also use a decksaver protective cover with an elastic (from the OP-1 packaging) and it’s a great combo to carry around. I also have enough room in the bag to carry either an OP-Z or the TX-6 :). Enjoy ![]()
Thanks, that’s super helpful actually. They only list exterior dimensions (32cm vs 31cm) both of which are more than the OP-1f, but if it fits diagonally…
Anyway, thanks ![]()
I’ve ordered the 9L Venture sling, will leave my thoughts once I have it ![]()
After a lot of research I opted for a flight-case type, called the Innox Impact Line 003 Foam. It’s a bit bigger than the cases listed in this conversation, but definitely solid, cheap (I paid 29€), it has some space for cables and other accessories, and it fits the OP-1 Field with the decksaver on. It comes with pre-cut foam so it’s really easy to make to measure.
that is a very safe looking op-1f ![]()
