To make it as trouble-free as possible, some testing would be much appreciated. Feel free to try it out with as much different gear as possible and report any bugs or suggestions in this thread. Please do not post this file outside of the forum.
Have a look at the release notes included to get an idea of what’s new. Refer to the manual (https://teenageengineering.com/guides/oplab) for upgrade instructions. A more complete manual covering the expansion port will be posted with the official release.
Note that this is a beta release and though it’s fine as far as we know, no functionality is guaranteed and using it is at your own risk.
Happy to report that SyncLab works great with the new update, also really like the dimmer LEDs on Oplab,they are now about the same brightness as SyncLab
The MIDI OUT works fine with a signal coming from USB and with a signal coming from MIDI IN ( Tested from a Pro2 )
But, for some reason, with a midi signal coming from an Octatrack via Midi IN, the vast majority of the notes are lost and are not sent to the other devices.
I don’t know which device is faulty, the OT or the Oplab ? When I send notes from the OT directly to a Nord Drum without OPLab, everything’s fine, so I suspect the Oplab…
Can somebody reproduce this ?
Edit : Turning off the clock send on the Octatrack solves the problem. So the OPlab, can’t receive a clock and notes from the Octatrack at the same time… weird.
Okay, just a cosmetic thing: While in Mode 2, the LED for CV1 OUT burns brighter than other LED’s. Also, the same LED in addition to USB HOST A (when connected) remain constantly illuminated; not sure if that is normal, but I don’t recall noticing it before - could be wrong.
Otherwise, THANK YOU SWEET BABY JESUS! SO APPRECIATE THE UPDATE!!!
