Again, the 0-coast contorelled by the Korg SQ-1 thru the Big Sky & the Organelle running the beat/bass patch called ‘Toussaint Trio’ thru the Empress Reverb.
https://soundcloud.com/aphew_goodman/brokenism-nr10
Another live jam… recorded the stereo file into my DAW… same equipment used as before…
https://soundcloud.com/pkrynx/darxxxith
Last saturday evening I played live with 6 other musicians and a visual artist.
OP-1 cv out 8 Korg SQ1 8 0-Coast + also used the Iter synth engine for some broken sequences (btw the Novation DJ splitter cable indeed works perfectly with the OP-1; now I have cv sync and audio out simultaneously
Here is the timelapse of the live improvisation of last Saturday, with a focus on the visual part of it.
@lyingdalai looks/sounds like a cool bunch of noise makers you’ve found in your new place. Good times
Yes indeed, and they really manage to leave space to each other, I’m super excited for having been included in this crew so fast!
Here is the timelapse of the live improvisation of last Saturday, with a focus on the visual part of it.https://www.youtube.com/watch?v=rlyWbMpSWlw
Cool vibes @lyingdalai
There’s an analog meet up on a monthly basis in Tokyo. Maybe I’ll make it one of these days. Working 6 Days is trife. Wish they could do it on a Sunday afternoon. Maybe I’ll just stay in my little cave and keep smashing the practice hours.
Made this summery UK Garage tune yesterday. I’ve been enjoying jamming something out and then trimming down the audio with some cut and shut business once it in the DAW.
I used the OB6 for the lead and this synth has been processed by the stellar BOSS CE-300. I mention this because it really takes whatever you stick through it into a metaphysical realm - somewhere like Shambhala!
I used the Sub 37 for bass duties.
Drums have been heavily processed through various devices including the Octatrack.
If I’m not making music then I’m fiddling around and reconfiguring stuff. It’s so fun!
Anyway… this tune is happy and I hope it makes you smile
A one-time live jam with volca beats and keys with an SQ-1 inbetween. A lot of meters in the red…
https://soundcloud.com/ollejohan/improvisation
OP-1 cv out 8 Korg SQ1 8 0-Coast + also used the Iter synth engine for some broken sequences (btw the Novation DJ splitter cable indeed works perfectly with the OP-1; now I have cv sync and audio out simultaneously :) )Also starring were the Organelle with four different patches + the Sub 37.https://soundcloud.com/aphew_goodman/brokenism-nr12
This is lovely. What Novation DJ splitter cable do you mean?
@ghostly606 My bad, sorry, it’s of course not any Novation cable but the Native Instruments Traktor DJ splitter cable.
My duo had a blog premier of a first single off our upcoming record. Some OP1 in there with a lot of Moog and some 0-coast blips.
Something new from me. Kind of monumental popdisco on broken straight beats.
Mostly Kaossilator 2 sampled into microSAMPLER. Strings from Workst…
Music for a ride in a glamorous car situation!!
My first OP1 track that i’ve tried to structure into something… Needs lots of work
Hi,
This is basically the first tune I ever put up on Soundcloud… Let me know what you think, every comment helps !
At 8 minutes it runs a bit long, but you know how it is when you have your hand on that cutoff knob…
https://soundcloud.com/tumulishoomaroom/atc-sidechain15
This started as a exploration of the modulation capabilities of a newly acquired Just Friends module.
Here are the more extensive patch notes :
Early explorations of the modulation capabilities of Just Friends in transcient mode, triggered by Noise Engineering Numeric Repetitor. The envelopes from Just Friends are modulating the Cursus Iteritas and the Loquelic Iteritas as well as the Cwejmann MMF-6. Some outs of the MMF-6 go in the mixer, one goes though the Ultrafold for further mangling. Voltage Block provides a simple pitch sequence to Loquelic and everything runs though the Verbos Amplitude and Tone Controller for final fuzz and a lovely master low pass filter. I also sent an envelope from Quadra to the ATC to create a sort of ducking effect.
Digitakt takes care of the percussion duties.
El Capistan for the tape delay and Space for the reverb.
Played and recorded live a couple times, I kept the take I liked best. Light EQ in Logic.
Missed this thread. Looking forward to enjoying the jams!
Here’s my latest effort;
https://soundcloud.com/pkrynx/darxxxound
Funky space jam! Good break before 1.58 min @HisMostDarxxxellent
Thanks @mixrasta! I really appreciate it. Multitracking stuff is not as fun as making a video but the sound quality is much better than adding effects to a single stereo file.
