Attempting to use step multiplier, but when following steps:
"press and hold any key 1-16 to select step while pressing bpm to insert a re-trig on that step. press bpm mulitple times to switch between 2, 4, 8 or 16 multiplier."
Did you press BPM multiple times while holding 1-16?
Yes, pressed BPM multiple times while holding step button. Each time pressing BPM, a black, 4-hole “button” (the kind to button a shirt) appears on the LCD.
[sorry for the reply on an old topic] This is most probably a bug. I think that the number 2, 4, 8 or 16 should have appeared next to the icon of the shirt-button. These numbers are on the LCD screen but they never show. It was probably not implemented during development of the PO-12.
yep, unused segments on the LCD.
it should show the multiplier # where the clock is when u press the button combo.
it should show the multiplier # where the clock is when u press the button combo.mine displays T-2, T-4, etc...
What button combo do you mean? Mine does not show T-2 etc.
the combo to set the retrig multiplier, step+bpm. see the clock
Wow! There must be different firmwares around. Because nothing shows when I appy retrigger (apart from the shirt-button icon).
hmmm! that is interesting. i’ve had mine for a while so it might be one of the earlier ones.
what does yours say on the back? maybe there is some noticeable difference…
I bought mine 2nd hand. So no idea if its newer or older. Just to be sure, the step multiplier (I call it “flam”) is activated this way:
- Select a sound (i.e. an instrument) w/ “Sound” + number key.
- While playing, press and hold a number key to select a step.
- Press “BPM/M” to insert a re-trig (flam) on that step.
- Press “BPM/M” multiple times to switch between the number of re-trigs.
When I press and hold a number during playback and press “M” for a flam then I do not see “t-4” etc. Only the shirt-buttun icon appears (every time that step is played).
what does yours say on the back? maybe there is some noticeable difference...mine says PO-12 TE010AS12A
I’ve put a lot of black insulation tape on the back because I was afraid that it might short circuit. Appears that most of the “reboots” were because of the “volume set too high” bug. Underneath the tape ain’t no numbering. And I glued some felt “feet” at the bottom.
yep same as what i’m doing.
also i get the shirt button when i enter the retrig into the seq i.e. press the button combo. as well as when the step plays back.
Where on the back is the serial number?
[edit] it’s at the bottom. Mine says: PO-12 TE010AS12A (just like yours)
at the bottom. not sure if its a unique serial number or just a model number.
there’s definitely multiple firmwares going around.
i thought u could factory reset on the earlier ones?
The number on the back is the product model, the serial number is in a sticker on the outside box
