Whoa, cool! Not really clear on what the mic is for though?
Mic is for data transfer from software.
This looks pretty cool if your in the market for a drum machine, have a PC/Mac and already have gear that would play well with it.
Whoa, cool! Not really clear on what the mic is for though?There's a video in there, the mic is used to receive data transmitted via speakers. Pretty cool. :)
Don’t really understand the utility of microtonic if it enables mic record
I wonder if the microphone import/export will also have instructions for the A/B parameter knobs? Or if the parameters will be
- the same across all drum channels -or-
- Specific to each drum channel, similar to po-12
Mic is for data transfer from software.This looks pretty cool if your in the market for a drum machine, have a PC/Mac and already have gear that would play well with it.
So basically it is a portable controler for a specific drum machine VST.
The previous POs are instant fun, you don’t need any configuration or any other gear to use them… Sorry TE but this is the first PO I will not buy
Don’t want to be a party breaker though, I know a lot of you guys will probably like it
Come on, you can save your patterns and recall them !!
So I assume without the VST it works just like any other 16 sound PO? Where there are 16 presets that are editable by the A+B knobs…If anything it seems like it would be cheaper/same price as the others (from a marketing standpoint, enticing you to also buy the software), but I can see how the production cost would be higher on this one.
Kind of a volca sample po, if I understand it correctly. In somehow…
So this a volca sample po, if I understand it correctly.
I don’t think it uses samples. Seems like it has the same synthesis engine as microtonic and you can transfer stuff back and forth. Synth based only?
Don’t want to be a party breaker though, I know a lot of you guys will probably like it![]()
The video doesn’t show it being a controller…
Is more like generate a set of sounds in your VST/AU transfer them to your PO and take them anywhere.
The microphone works picking up the modulated audio and then the MCU decodes the data that turns into a sample playable by the PO. Unless the PO has a sort of VST engine in there.
Awesome!!!
Come on, you can save your patterns and recall them !!I was so sad when I had to erase some very nice sounds out of the PO-16, I'm so glad one now offers to exchange data with a computer...And I though I would never buy POs again...:D
Ok you can save your patterns. But it is a drum and percussion synth, which means saving paterns is - for me - far less interesting than it would be on a PO-16 or PO-28 for instance.
Plus using a computer… It is a crime for such portable devices as the Pocket Operators
Yes, it’s not a controller per se. Has same synth engine as the Microtonic, but you will be able to assign two values to the A / B knobs. For under £100 it seems like a pretty nifty device. Bought and sold all the other POs, might just try and avoid this altogether but can see the attraction.
neat
I understand you can use all of the features -minus backup- without a computer ain’t it?
and minus changing the kit I believe?
I understand you can use all of the features -minus backup- without a computer ain’t it?It would be great if you could save the presets in a recorder or the OP-1 without a computer. I do think this might be possible as well!
