Pocket Operator Encoder Jumping/Sensitivity (PO-33)
Hiya
I’ve recently bought my first PO and it’s the PO-33. I was wondering if an issue I have with it is normal to other users, or if I should be returning it to Juno for a replacement (it’s new).
Basically I find the second encoder very tricky to get to where you want and it sometimes jumps up or down a number of values after I have let go of it.
I’ve made a short video to demonstrate what happens when I’m trying to adjust the BPM (typically it wasn’t doing it as bad when the camera was rolling), but this gives you an idea of what I’m talking about: https://photos.app.goo.gl/6MJtJmLErXULye8m7
This seems a bit annoying to me, but are all POs like this?
Cheers!
I think it is a normal behaviour. My Po33 acts the same. It is annoying, but you will get used to it.
Okay, thanks. I’ll persevere! Cheers.
i swapped the pots on several POs and the jumping goes away completely
Thanks. I might do the same sometime.
