Can you put a 6min stereo .aif file onto Op-1 as the album file?
Anyone tried that?
Have you?
Yes, and it did not work.
Interesting thought. You could have a huge library on their for recording samples.
I think itâs a bit more than just an aiff file.
For example all the presets etc are all just aiff files too but manage to have effect info in there etc too.
i hadnât tried this until i saw this post, assuming i could but i had not done so yet.
i copied âside_a.aifâ, opened it in audition, replaced the audio, made sure it was exactly 6:00 and resaved it. i dragged it to the album folder on the OP-1 and replaced the existing one.
when i ejected the OP-1 it rebooted and defragmented the hard drive, after that my new âside_a.aifâ played just fine on the OP-1.
Thatâs pretty interesting trojan!
Iâm going to give it a try with tape tracks 1-4
@trojan so you are certain that the file you put back in actuall y played?
I am asking, because i even tried putting back on the OP-1 an album file i previously copied from it, and it still did not playâŚ
Tonight I tried exporting an aiff mono file from ableton live and replacing one of the tape tracks.,
I will have close look at the album file to see why importing a new aiff is such a ball ache.
What do you mean take a close look at it? Analyse the file somehow? If you are then also check out why tape import wonât work too.
It would be amazing to find a way to make it work!
@spacetravelmadeeasy if you change the file name to track_1.aif it will work. That includes changing the file extension to .aif even after your computer warns you not to. .aiff and .aifc will not work. Have fun!
@trojan so you are certain that the file you put back in actuall y played?I am asking, because i even tried putting back on the OP-1 an album file i previously copied from it, and it still did not playâŚ
yes, positive. i did it twice to make sure, since the first time i uploaded the wrong file and wasnât certain it wasnât already on the album. the second time i made the track very distinctively different. i am assuming it will work for tape tracks as well, in fact, i think i have done that previously. i plan to set up a few songs exactly as spacetravelmadeeasy said. setting up as many sets of grouped tracks as i can fit in 6 minutes, each group being a song.
my thought is that i can cull tracks i have made on the OP-1, back them up, then later put them all into a multitrack session that is 6:00 or less, save out each track to load into the OP-1, then set loop points in those tracks so i can play them back properly.
the reason i opened, edited and re-saved the file i had taken off the OP-1 was 1) to ensure i was at the correct sample/bit rate and 2) in case there is any header info or meta tags or some shit that i donât know how to âtake a close look atâ.
Thanks @sammyjams will try that tonight
I will have to try this then @trojan
i was able to make, and place the tape tracks on the OP-1 just fine. but it did not work with the album.
will try using the original file, and just swapping content.
Just tried replacing the tape files and it works!
very interesting stuff in this thread thanks all!@
beats me why TE donât just release enough technical documentation to enable desktop apps extending the OP experience.
For people trying to put together sets out of tape stems, remember that you can loop an area of tape by holding shift and pressing the loop button on the tape screen. Then you can mix loops that donât have to be in the same tempo or time signature.
Also, you can cut your tape to different lengths on different tracks. What might be an 8 bar complete loop can be broken up into two bars on track 1, four bars on track 2, one bar on track 3, and eight bars on track 4 for instance to allow you to shift+loop different regions of an arrangement on the fly.
I remember the first battle on ohpeewon, if I recall it correctly, we got a side_a.aif file and just put that on the album. It was the Paris in April thing from Duke EllingtonâŚ
