So far I’ve failed to sample audio sources that have an 3.5mm out into my OP Z.
I’ve tried TRRS to TRS and a TRRS splitter.
3.5 to usbc adapters probably won’t work because they are meant for using headphones on smartphones that only have usbc out
And if you don’t wire a custom TRRS cable that splits the mic touch point you are going to have to use usb c audio in on the OP-Z
My main questions are:
What dongles could I use to get 3.5mm audio into my OPZ via usb-c?
Would a Y-type TRRS split cable work differently than lets say a Røde TRRS splitter?
just found the Screen + 2 input selection tip here - that was driving me nuts since i thought opz would auto select trrs input once something with a 10k resistor was connected youtu.be/ZzYdZRxZFR8?t=56
