I really want to love my OP-1, but the whole ‘cant record a loop without having zero crossing pops’ is driving me fucking crazy.
If you can deal with attack and decay in your sound, that is the only way I have found…
or a zero crossing in the sample before loading…
i want to know what TE is doing because someone there (not throwing them under the bus…) claims it never happens to him o.O
WHOOOOOO SAY IT NEVER HAPPENS!!!
LIAR!!!
not you KrisM… whom ever says never!
I think I’ve settled into a workflow that mostly avoids pops and clicks. Unfortunately though, it means I tend to avoid using the approach where you add layers to a continually recording loop. I still do loop based work, but I tend to build my loops up in such a way that no sound crosses a loop boundary. (I agree though, to have to do this is a shame and it limits what you can do with loops). When I’m happy with a skeletal loop and want it to play over a number of bars, I’ll lift and drop it that number of times onto tape and shift into a more linear workflow (something akin to the arrangement view in Ableton). Once I’m in that mode, I’ll add all my longer, pad-type sounds in separate passes on top of the looped material on tape.
I don’t remember where I read this, and I tried to find the link to the blog that mentioned it, but
@THSC That’s the point of the USB charge disable thing. That option (I assume) isolates the grounds of the USB cable and the OP-1 (USB data transfer still works, because it’s a differential connection, doesn’t need a common ground). Less chance of ground loops and ground noise and such that way.
I just don’t sample with my op1 anymore.
I bought a Octatrack which also Pops & Clicks. So i can split up my anger on both machines …
@ifeelokay on OT there are two settings for Recorder Fade In and Fade Out, to avoid this precise problem.
Right. 3-5ms on either end eliminates all but the most aggressive pops.
@Unflattered mind explaining further ?
I recall from previous threads that tape loop clicks are caused by the OP-1 jumping back at the wrong place in the sample memory, i.e., the start/end points are stored using a timestamp that has not enough resolution to point to the correct place. Simply cross-fading may not be the solution here and the fact we still have those issues appears to confirm that it can’t be easily fixed by TE.
A ms fade in (from zero) and fade out (from zero) is usually enough to add silence @ the crossing, but quick enough to no dampen the audio.
Got Audioshare on the iPhone or iPad? When you use it to crop loops, this option is user-definable, and enabled by default. It’s pretty much perfect at eliminating pops @ zero crossing.
I recall from previous threads that tape loop clicks are caused by the OP-1 jumping back at the wrong place in the sample memory, i.e., the start/end points are stored using a timestamp that has not enough resolution to point to the correct place. Simply cross-fading may not be the solution here and the fact we still have those issues appears to confirm that it can't be easily fixed by TE.
A little more attention to correcting their flagship problem would be highly appreciated. PO units are great, but the real TE investors suffer while their crew prances around the altar of a $50 toy.
@ifeelokay on OT there are two settings for Recorder Fade In and Fade Out, to avoid this precise problem.Look for FIN and FOUT in the second record menu (p.52 of the manual)
@Unflattered mind explaining further ?A ms fade in (from zero) and fade out (from zero) is usually enough to add silence @ the crossing, but quick enough to no dampen the audio.
Yes, I get that part already, sorry for not being precise enough…
“Right”, meaning a fade in / out would be the solution.
