Testing Cases for OP-1 Field
weird :frowning:
is it the dye in the fabric?
wonder if u could throw it in the washer a couple times to get it out if so?
the case not hte OP obv haha
no matter what case i use… i always carry the OP-1 and OP-1F with decksaver on top. i think that’s the most reliable protection
Yes tried it already. My cloth was almost full black. I think i don’t take to rist to use it.
Does anyone know if the meme antenna case work for the op-1 field (with adjustment if needed) ?
The Analog Glide has worked perfect for my OP-1 Field with DeckSaver. Just spin it 180° so the encoders are farthest from the hinge. That way the encoders keep the pocket contents in place.
Wow, that looks very very nice.
Thank you, I like this combo too. It is the leather wrap with the OP-1 field defender. You can find the latter here:
It helps notably to prevent the on/off button to be triggered by mistake. Very useful
Okay so I’m slightly late to this discussion having just bought an OP-1 Field and the original white case. As others have stated it is a tight fit. By stretching it I have found it much looser and I believe (having not yet purchased it) that the Decksaver would easily fit with any tightness.
My method of stretching was a 1.25l Diet Coke bottle!! Inserting it into the case was a pretty tight fit but easy enough to get in and out (with a little pulling). I left it over night for full effect :slight_smile:
A simple solution but seemed to work for me.
Have you kept using this case during the past 2 years? Is it aging well? Has it stained your OP1 at all? In essence, would you still recommend it?
Thanks!
imho since the device is 2k, best not skip on a good case. i travelled with it in my loose backpack for a while just wrapped in a pillow case and it was fine but ive come to the realization its a big stupid risk. what i have now (since ive been traveling more and really dont want the risk) is the official white field case PLUS (very important plus) the Decksaver plastic case/cover. i put the decksaver on the op1f and then put this nice safe duo inside the official white field case. i think its the most protective option that ive found that doesnt involve rigging something in ways that are too inconvenient.
Decksaver + analog case Chris :slight_smile:
https://www.etsy.com/listing/1497977357/fanboy-op-1-field-travel-companion?etsrc=sdt
going thru each and every comment in this post i am still struggling to find a solution for op-1 field with decksaver on it. reason being - the power switch and the accidental on/off.
i wish decksaver could offer the same power switch protection as it is with tx-6. hope they will come up with similar solution for the upcoming op-xy cover as the op-1/ op-1 field simply doesn’t fit anymore (because of the pitchband position).
will appreciate if someone shares experience with some detailed pics. i know there are already many above, but how well op-1 field fits in a particular case/pouch, and most importantly - does it touch the power switch?
Only one choice
Decksaver + analog hard shell case
Agreed. I’ve travelled all over with mine this way, planes, trains, bikes, hikes, etc and never had a single issue with the power button in the Analog case. The corner edges of the OP-1 push agains the inside of the case, not the power button.
thanks.
this is with the decksaver cover on it?
Yes, I always leave the decksaver on when it’s not in use, even in the analog case. They really are the perfect pair when protecting your OP-1F.
but only the newer ones, interestingly my first gen Decksaver for the OP1 fits the chroma capped OP1f perfectly, without touching the knobs and the „new“ one is perfect for the OG OP1.
there’s a little difference in height and I think they‘ve changed the mold within their production run, it’s also a bit thinner.
I am selling one of my wooden cases from Synth Toys. Happy to ship anywhere in Europe. I have two and use the other one daily on my Field. It’s obviously super sturdy and the Field can stay in the bottom case during use.
