^Yeah, I have the K-mix.
Happy with it so far, but I think I’m not utilizing it to the fullest
I run two Elektrons, a Micromonsta and a modular through it and it’s very flexible for e.g. routing stuff to the Octatrack for sampling. Two button presses to send.
On my to-do list is at least more extensive utilization of the compressor, checking out the DAW control options, creating a few nice presets, etc.
If you have any questions, fire away.
I’ve just skimmed through Cuckoo’s “No Computer” video, thanks ! Although the basics functions seem pretty straightforward it also seems to be very deep. I guess my only question is does this thing has a huge hidden gigantic flaw ? Because it almost seems to good to be true. I mean this thing manges to bring excitement to the dreaded mixer/audio interface purchase.
@hindsite I'm thinking about upgrading from my Dispatch Master to the Avalanche Run. Worth it? Is it as lush as I think?Probably not helping but :
On my part I just discovered the Keith McMillen K-Mix and this thing looks incredible. Exactly what I want : very small footprint, extended capabilities, audio interface AND mixer (and controller but i don’t care much about that). Does anybody have any experience with it ?
Damn, that pedal looks nice… Added to the list
Chase Bliss - Tonal Recall
Hologram - Dream Sequence
Red Panda - Particle
Soundblox_pro - Poly Mod Filter
I've just skimmed through Cuckoo's "No Computer" video, thanks ! Although the basics functions seem pretty straightforward it also seems to be very deep. I guess my only question is does this thing has a huge hidden gigantic flaw ? Because it almost seems to good to be true. I mean this thing manges to bring excitement to the dreaded mixer/audio interface purchase.Well... It's definitely not an urgent purchase but I'm a bit frustrated with the Scarlett 2i2 I have : nearly not enough in/outputs + dependent on the computer... etc. It works perfectly but I guess I just want to upgrade a bit later down the line.
No big flaws that I’ve found. One thing to be mindful of is that it’s not as ergonomical as actual fader-equipped mixers. No dub-style fader throws, not without some practice
@hindsite I'm thinking about upgrading from my Dispatch Master to the Avalanche Run. Worth it? Is it as lush as I think?I don't have one yet. But it's very high on my list. Mainly due the video @tumulishroomaroom posted. It's a great YouTube channel that BTW. I've read great reviews about it too. Very versatile by all accounts.
Have a red panda particle - love it. The YouTube channel you posted of the avalanche does a good demo of it - great channel it is!@hindsite I'm thinking about upgrading from my Dispatch Master to the Avalanche Run. Worth it? Is it as lush as I think?Probably not helping but :
On my part I just discovered the Keith McMillen K-Mix and this thing looks incredible. Exactly what I want : very small footprint, extended capabilities, audio interface AND mixer (and controller but i don’t care much about that). Does anybody have any experience with it ?Damn, that pedal looks nice… Added to the list
Very GAS-inducing channel, yes…
Damn these pedals are awesome !
The K-MIX is still my main audio interface, mixer, midi controller. I like to keep it relatively portable and small.
Cuckoo's list
Great list!
Thank you for this comprehensive list. Very helpful !
Cuckoo's listGreat list!
One thing though: Point number 1b on the negative side. I drive a pair of Sennheiser HD 600 headphones from the headphone out… I would probably kill my ears if I went full volume on the K-Mix… And these are 300 Ohm headphones. Maybe you listen to stuff full blast?
Hmm, this is interesting @cuckoo – I do monitor at a fairly low volume, I guess. But for me, with the 300 ohm Sennheisers, I put the volume about a quarter of the way up – anything over half would definitely feel really uncomfortable.
With ATH M-50X’s, I actually struggle to set the headphone volume low enough. I think these are 38 ohms.
Could there be some difference in hardware? Or just way different listening habits
With ATH M-50X's, I actually struggle to set the headphone volume low enough. I think these are 38 ohms.
Could there be some difference in hardware? Or just way different listening habits :)
Weiiiirdd… Ok, looking around in the Editor now. And right in my face, there it is. Headphones output gain:
Nice! Hope that sorts you out.
Relating to this – in case it’s of any use to someone:
I actually tend to geek out over stuff in that, uhm, “pre-purchase” phase and researched a bit:
Apparently the output impedance of a mixer/interface is important when considering suitable headphones. A rule of thumb often followed is that the output impedance of the device driving the headphones should be AT MOST 1/8 of the impedance of the headphones. Thus if I have a pair of 300 ohm headphones, the output impedance of the K-Mix should be at most 37,5.
KMI state in the specs that the output impedance of the K-Mix is “<50 ohms”, which is sort of vague. I went on a multi-hour research spree and the issue is very complex – it’s not always straightforward what is better for listening – but I eventually got the idea that this impedance mismatch is nothing to be worried about in my case (even if the output impedance of the KMIX was the “worst possible”, 50). Basically, I understood that with headphones, you want to worry about 2 things:
1) the 1/8 rule (even though it’s splitting hairs, the differences might be negligible) and
2) that you get sufficient volume for your needs.
Headache warning, here’s further reading:
http://nwavguy.blogspot.fi/2011/02/headphone-impedance-explained.html
http://nwavguy.blogspot.fi/2011/02/headphone-amp-impedance.html
@cuckoo, out of curiosity, could you please clarify “ins outs and master around half level” - what does that look like?
@cuckoo, out of curiosity, could you please clarify "ins outs and master around half level" - what does that look like?
Basically it means that during the recording and mixing process I don’t want the audio levels close to hitting the distortion limit. I want headroom to play dynamically. If everything is already at maximum, it will start clipping if I go above it. And if I want to monitor vocals, I want that typically a little louder than everything else. If everything is already maxed out, I need to turn everything down.
Also, this is just a feeling, but if I record stuff at a more mid level it feels easier to mix. I don’t know why. Perhaps the audio levels are a bit flatter at lower volumes? I’m no pro there.
