This is not really true.
Nearly all Headset mics are using electret capsules. They need always a polarisation voltage to work. Therefore every TRRS jack has to provide this voltage [Volt]. The current [Ampere] flow is near zero. Therefore the power [Watt] is near zero aswell.
But still they need this 5V to work.
Please check second section âPlug-in-powerâ of this article :
u may be right as well but i was trying to help ppl differentiate between these two schemes
and avoid confusion
when u say âplug in powerâ for 99% of cases u are referring to this wiring scheme for the TRS jack
TIP = microphone input signal
RING = 5v power
SLEEVE = gnd
and these types of mics that were made to integrate with this scheme
this is what i believe they are referring to in the wiki link u posted
old computer soundcards used to have these types of jacks // schemes.
very common back in the day. not so much anymore. TRRS headset is much more common now.
think of those 90s wand microphones
now a TRRS is setup like this
(sure they are a few slightly different wiring schemes but none of them have a 5v rail on any pole)
TIP = LEFT OUTPUT
RING1 = RIGHT OUTPUT
RING2 = GND
SLEEVE = MICROPHONE INPUT
in this scheme there is no power being sent to the microphone like how plug in power works
this is the message i was trying to convey with my word choices
plug in power and trrs headset are 2 different things basically
if u plug a TRRS headphone & headset into a plug in power type jack it is not going to work
and same for vice versa
words are so easily misconstrued and misinterpreted
its no ones fault. like i said was just trying to help
maybe i created more confusion, i dunno
Plug-in Power and TRRS is not a different thing. The key of Plug-in Power is that 5V is on the same line as the audio signal and then diveded with an RC Filter.
Therefor the TRRS pinning is:
TIP = LEFT OUTPUT
RING2 = GND
SLEEVE = MICROPHONE INPUT + 5V PiP
In reality most devices like smartphones, laptops, gaming consols just provide a voltage of 1.5 to 3V and thatâs enough for most headsets.
from what I can Google, there is a difference like docshermsticks noted.
âplug-in powerâ seems to typically use the sleeve as the negative end of the bias, and the tip/ring positive. TRRS headset power does positive bias on the sleeve.
at this point, probably best to table the discussion till someone with a unit can verify exactly what it doesâŚ
Have you tried this mic with the TP-7 already? I still have to use the Minidisc for it to work as expected, even though I always keep the battery well charged on it
IRL itâs as gorgeous as youâd expect and also the feel is incredible. I want to keep it around literally all day. The ability to record a voice memo with a single button even when the unit is off is pure bliss.
Feature wise itâs all good, except for the baffling lack of a built-in stereo (condenser) mic. I cannot fathom someone sets out to make the ultimate field recorder and then leaves this out. I somehow missed this in the specifications and Iâm likely to return the unit over just this.
What doesnât help is a few QA issues: screen blemishes, flutter in audio playback when the disc is moving, flimsy-feeling power button. Not big issues â except at this luxury price point they do become issues.
Tp-7 arrived
Everything works as advertised .
No defects I was a little bit afraid after all the horror stories, but I am very happy.
Recordings sounds great.
And the wheel is very smooth and fun when using.
I get flutter from the wheel as well, but I have let it play some high quality WAV files for several hours one day and I no longer notice warbling/flutter at all. Initially some folks suggested this was due to magnets near the rocker, but it appears that minor bumps while the wheel is spinning will cause it to flutter, so it needs to be on a stable/stationary table while rotating. Iâm hoping a firmware update comes relatively soon that allows us to modify the wheelâs sensitivity.
I have zero problems with the buttons clicking at the start of recording though, IMO itâs a non-issue because every use case I personally have for it will allow for me to modify the audio files themselves.
Using the three input/outputs as outputs for 1 track per output to three portable speakers is magic.
The three outputs have their own track and the Tp-7âs own speaker has the full mix.
The record this with. Stereo mic into the op-1f.
Spacious bliss
I got mine about a week ago via Perfect Circuit (it shipped earlier, but I was out of town and couldnât sign for it.). Itâs great. I think youâll really like it. Worth the wait.
