TX-6 mixer
Hi everyone,
Is someone able to help me setup BLE start-stop messages from TX-6 to OP-1F? TX-6 as host. I had it working in the past but can’t find the right settings anymore.
Thanks :pray::pray:
Confirmed that TE broke it in the software. I will contact them
For the time being i need a usb c splitter to connect the op-1 field to the tx-6 and for my usb c drive to record onto. Does anyone know if this one will work?
It will not. That’s a power splitter for charging.
What you need is a two- or more- port USB-C hub. I don’t have a good one to recommend, despite having done some research. I’ve been looking for a small one with at least two USB-C outputs, one USB-A output and a microSD, and nothing else. If anyone sees one like that, I’d love to hear about it.
Kingston Nucleum ?
Thanks! Maybe? I see the USB-C data port; the spec sheet says the other one is “USB power”. I wonder if that’s just power, or power+data.
At what it costs, it’s tempting to pick it up and see; there’s other stuff I can probably use it with, or give it to my wife for her Lenovo.
In general there seems to be an issue detecting usb if it’s plugged in before turning on. It’s not detected with an ios device unless it is already on. Seems like a bug!
I love my Bluebox! Saves not having to use a laptop to record tracks on the fly. I need to figure out how to record my OB-4 to my Bluebox but think mike the OB-4 and output to Bluebox
Would it be possible with an update for the OP-1F to send the 4 tape tracks separatly to the TX-6 ? I mean it would be amazing if we could mix the tape tracks directly on the TX-6 with the FX, and send them back into the OP-1 tape recorder. Can it be done with the software, or is it something limited by the hardware ?
If this is not possible, maybe we could at least control the tracks parameters with the TX-6 via USB or Bluetooth midi ?
I would like to confirm with you that running the factory reset function does not reset the master, AUX and CUE volume levels. Are these values also unchanged on your devices after the reset?
I got those Amazon slim cables but does anyone know if TE’s cables are slightly slimmer than Amazon’s?
Having on an angle certainly helps with the operation!
Nice! Where are the stands from? What’s the black thing above the mixer?
I made the stands. Have done a few different ones.
The black unit is a little spectrum analyser off eBay.
where to buy for the tx6?
Awesome work! Tx stand is nice!!
Not selling them buddy but happy to share the plans and you can get one cut out
would you mind to sell yours? or could you cut it out for me? :orange_heart:
Where are you located?
DM sent
