...I use dedicated hardware recorders.
I too am hardware only. Use Logic 8 or Bias Peak for audio edits only. I like Reason too, but use Reason 4. You talk about Rack Extensions, well I am pre Audio tracking. ![]()
I have a couple of Tascam ones, a Zoom H2 and a KorgD888.
Fostex D108 and a Traxdata CD recorder.
Traxdata seeās most use with its remote control and quick record.
Boss BR600 and Micro BR here.
Any of these recorders have MIDI?
Fostex D108 sends out MTC and Midi Clock ,but only recieveās Midi clock.Most equipment canāt trigger it to start (only use clock)but OP-1 seems to (and I did test it).Iāve maxed out my iCM4 and have a lot to play with,so havenāt been persuing that-but it works great with an Atari St running CuBase.
I was thinking about getting a Behringer UFX1204 to use with my OP-1, couple of Volcas, Nanoloopā¦
Incase you havenāt seen thisā¦
https://www.gearslutz.com/board/low-end-theory/907790-alesis-io2-vs-behringer-xenyx-ufx1204.html
The older Behringer gear Iāve bought had inferior effects quality and build, but they may well be improving.
Someone on Korg Forum said their Xenyx had very good sound.
Anyone have any other mixer/recorder tips?
Iāve had a long out-of-production Korg D3200 harddisc recorder/workstation for like 10 years which these days gets most of its live-time as the rehearsal space-mixer and recorder. This is a great piece recording equipment if you need to record up to (but not more than) 12 channels simultaneously. I never used it for editing, mixing and mastering though, because that tiny screen makes all this impossible (there are/were some DIY VGA-converter kits available online, with one of those you can plug in an external monitor, which you normally canāt do on the D3200ā¦).
Find someone with a Live Lite license and go free. It comes with many new controllers/midi devices and soundcards so they can be scrounged up quite easily from a friend or bandmate.
Reaktor exclusively for Twisted Tools.
Iām using Ableton Live Lite 9 as my first DAW. Will definitely upload to Standard or Suite eventually, but even the lite version has tons of good features.
Ableton Live, Logic, Reason, FL Studio, Triumph
I have an X32 and Protools 12.8 for tracking if i need it fun to just do it all in the Box tho with the OP-1
Iām another one of those āno computerā peeps, except for audacity. Iām trying out recording to a Tascam, but Iām not sure how much I like it. What I really want is basically a digital mulitirack with the usual stuff, but OP-1 tape style.
Also: outboard fx. So many multitracks out there and so few of them have sends to external gear.
But if I wanted more from software Iād probably try to use Ardour until I broke down and got Live. Not a big fan of these though, I cut my teeth on trackers and donāt have much patience for anything that expects you to have a mouse. (I wish I still used trackers, I want a reason to pay for a Renoise license.)
Live 9 with push 2. I was using FL Studio for many years before that, but Iāve totally stopped using it since push.
My āday jobā (writer for Computer Music magazine) requires that I use pretty much everything. However, when itās time to record my own music, I fire up Cubase - primarily because I have a lot of outboard gear and it still gets on well with most of the old MIDI stuff. It has some decent included synths and effects, though I tend to use outboard gear more in my music simply as a change from my day-to-day work.
