What Would You Want in an OP-ZF?
Quite interesting to see the TE team explaining the field series, with some surprising response to the… “is there an OP-Z Field coming” question. As Oora said on his video.
Answer @ 21.40
Another interesting thingy of note was that they tried to make a mixer half the size of the TX-6! But then a game of cards broke out in the office and the size-factor became obvious.
(I may have made that last sentence up).
I’d love to have been in that room just to ask them;
“One of the benefits of being a small company must be that you retain a tighter level of control, with regards to production runs. So at what point were you aware of the warping issues with the much-loved op-z? And would you care to explain what’s the cause of this, why it’s not been addressed, nor fixed, and why as a renowned design company you feel that it is perfectly ethical to still sell a relatively expensive product that you know is fundamentally flawed?”
Another interesting thing of note from the video above was that they are releasing something new this year after summer.
My guess is that will be the Field-speaker. No one is gonna use those spare slots for an extra
TP-7 but I could defiantly see a mini speaker (or stereo pair) that looks like the CM-15 sitting in there.
https://teenage.engineering/store/field-delivery-bag/
Most probably TX-6 was reworked prototype of mixing player TE tried to develop for Kanye West (but he picked another company for his Stem Player).
  • Metal body
  • Better switches to avoid double triggers
  • Screws to fix the board instead of melted plastic, so we can easily clean contacts
  • Separate samples slots and engines slots, so they don’t compete with each other:
    • Fixed slots for synths engines and FX, no need to assign them with the app
    • Each of the 8 first tracks have 10 usable samples slots, always
  • LFO on arp track
  • Steps components on ALL tracks, incl. module, master, tape, fx & performance tracks
  • Configurable filter tracking amount
  • Configurable probability on the random step components value
  • More sound engines, or better a port of Plaits engine: 2-op FM, waveshaping, wavetable, formant, additive, hypersaw…
  • Switchable drum synth for the first 4 tracks, based on Microtonic
  • Optional “advanced mode” with 4 added parameters per engine (= 1 extra page)
  • Added insert FX per track (overdrive, phaser, chorus, bit/sample rate reduction…)
  • Stereo sampling
  • Up to 64 steps sequencer (4 pages)
  • Records pitch bend data
  • Built-in rumble and line-in modules
  • Upgraded battery
  • Full backup/restore from the OP-Z app
  • Still no screen :slight_smile:
-Alu case with rounded corners
-OPZ App in AU format (now we have Logic for iPad ;))
-Stereo samples 24 bit
-Much more memory please
-Small screen (like the field mixer)
The small screen will only show the sample pack name or the dials selections
-Export Stems in separate audio files
-Export loops without effects option
-USB multi channel interface
-New reverb
-Side chain effect
-More Patterns use
-Same compact size please
-Bigger trigger buttons
-Stutter effect (like the logic iPad beat braker)
-Managing samples with the app
-2 extra send effects
-Tape echo simulation
-Recording much lager files
-Vocoder like effects
-Granular effect for samples
Add: Resample to a drum sample track so you can slice & dice.
I recently realized, that all the limitations of OP-Z don’t prevent me from making complete tracks on it, but there’s one thing that absolutely has to be done in post-production, and that’s compression. I really dislike single knob compressors, so I’ve found the built-in OP-Z compressor completely useless. It’s better to disable it and use MDES later.
If the OP-Z field ever blesses this world, I hope it has a decent compressor.
Well, I wouldn’t say no to better mixing tools in general, but at least please give me a usable compressor.
Personally I’m quite happy with the ergonomics and the UX.
1 - Would definitely love to have better live-effects intensity modulation using the pitch-touchbar (e.g. to modulate stereo effect or balance between clean and effected sound).
2 - Better stereo workflow (but that is probably already assured).
3 - More non-geek-oriented functions for integration in an electro live-set (e.g. dual op-z pairing or live file swapping if connected to USB c)
4 - Retro-lit or with a tiny led keys, this should have been on the OP1 field as it is hard to see what you press on in dim environments without external light (e.g. stage…).
Cheers
:slightly_smiling_face:
z
