ok, not a module as such, but a TE-Hub. On the rear could be SD/usb(power for internal batt) 3.5mm main out/in/ 10 x 3.5,mm aux outs/cv in/out/midi in/out. On the front, three Oled displays, the main screen being video/vid paks/info/like our current ios app. Either side being touch responsive-volume/pans/additional info etc. Inside the top casing, speakers but also wee lights that can project/be controlled by the DMX.
Inside the unit you can store samples/patterns/nfo/settings.
for the op-z / op-1. £999 (TE price) or £599 in the real world. Not made of plastic that warps x
its the arse-end of a cheap biro, although they do vary in size so its bit of a gamble to find the right one, but it works. I had to improvise whilst on holiday and its not let me down yet (what can i say, im a cheapskate;) ).
Btw, I also don’t think analog synth modules would make any sense because that kind of circuit takes too much space, even for a single voice it would likely require custom ICs, like the Elektron AR or DSI synths. And then what, re-ssample the analog output back into the OP-Z?
Anyway, I will tell my crazy idea (besides the aforementioned FX send/return module): an EEG module that records brain waves and allow you to control the OP-Z sequencer with your mind!
Gimme a module, call it Lazerpak, that shoots out lights and works with that whole dmx lights track part of the z
OR (and this is perhaps beyond the realm of feasibility but) gimme a little projector to spit out those fun little animations or i dunno like a strap connection module so you can keytar that bad boy
An extra battery? I would expect this thing to have 15hours of battery life since it doesn’t have a screen.
Also, some really good suggestions above! A 32gb memory module like the old ps2 memory cards would be awesome. But they would have to allow recording of each track individually into a folder to use after in my DAW
imagine this idea with an inserted SD card and some kind of tape flutter etc. but I think we’ll see other tape track plugs in the near future and master fx plugs
More plugs in general would be an awesome (and easy) addition to the OP-Z. More FX, tape FX, master FX, and synth plugs (Adding a chorus to my master is just something I don’t want to do). Just additional diversity and options in general.
Something connected to a t shirt so we can wear the controlled lights and then a speaker backpack that bumps. Probably include a fog Maschine in the backpack
An obvious module would be a variant of the oplab. But have 8 outputs (4 stereo outs) of just triggers. So you could sequence modular drums. Like Hexinverter’s Mutant Brain.
Actually, this should just be an update for the current oplab module.
I would really fancy a module with 4 mono inputs where you could place recorder trigs on the module track, so one could get automated sampling a la Octatrack.
I don’t think we will ever see the sd sampling card module, TE has always added a limitation to their products regarding storage, that would be odd given its flash memory size…
Yes, I think it can be implemented thanks to the module track, which could have its own buffer.
I’m afraid we will never see this, TE has always been unpredictable and far away from users’ expectations, be it good or bad
