Iād love if they had a āmetaā sequencer that would let you chain multiple sequences from any of the other sequencers. That would basically cover all my needs.
Soooooo
Synth sampler and drum samplerā¦Has the recording time limits increased for either? Cant seem to find anything in the manualā¦
I had seen in this thread that the overall memory has increased but sample size is still 6 seconds.
On the contrary, a video stated that sample length has increased to 20seconds
Maybe one of the beta testers could answer this?
@MichaalHell
Oh thatās great news, I hope i was wrong!
somewhere it says increased to 20 seconds
not sure if htats just for drum or what but i saw it a couple times
ya right here on the main page
Hi!
Drum sampler is 20 second and synth sampler is 6 secondsā¦
who here has first hand experience with the OP1F and can share impressions about the display brightness and UI feel?
Im hoping the synth sampler gets increased from 6 seconds. I loved the OP-1 but was never a fan of the synth engines so used to multi sample stuff in
Im not pulling the trigger until a few things get sorted (need some restraint) -
Drum sampler has been increased to 20 seconds - great. But the synth sampler is 6 seconds. I feel this needs to increase as i used multi samples more than the OP-1 synths
Velocity needs to get implemented
Maybe seq save?
The RRP is still a little high as direct from TE atm. I expect vendors like Juno to start selling these at £1750 (plus they usually have a 10% discount). This logic is based on the older OP-1 being £1400 direct from TE but Juno (and many other vendors infairness) are selling around £1100 right now.
And generally its not great buying something at FW 001, lets get a few more updates under its belt
So yeah in about 6 months time for me. Pretty excited to see these in the wild on youtube.
Iām about to add a Field to my 2 originals.
Iād ordered a 3rd Op-1 but cancelled when the Field was announced.
Not my intention to be flash about it. Just that the 2 Op-1s are my entire setup. And with the announcement of the Field I simply wanted to experience the new machine. Interestingly Iād always been a bit too paranoid to take them out and about. And Iām certainly not going to take the Field out. So my mindās more relaxed about taking the OGās out now.
Iād love to know your feedback about this when you get it.
I wonder how the OG aliasing sound could be missed. For instance, when I play the drums with the Endless sequencer, I enjoy playing with the octave, especially octave down with a bit of Spring reverb. Makes some nice sound, with aliasing. Iād miss that!
Thatās one of the reasons I wonāt consider the Field as a replacement, until/unless I feel otherwise.
I have a question for the more technically inclined.
The OP-1F has a dual 2.4GHz antenna system, I assume thatās for the radio transmitting?
Isnāt that what devices use to connect to Wifi too? I think my router has 2.4 and 5GHz.
Iām curious if thatās true, and if that means there is potential for Wifi activity on the device as well? obviously not for web browsing but maybe for wireless sample/tape transfer or something.
The radio should be transmitting on ~88MHz-104MHz, so it must use a separate antenna.
Bluetooth and WiFi do use 2.4 GHz (and WiFi does use other frequencies, like 5 GHz, as you say). Itās hard to know without prying one open and looking at the chipset as to whether it might do WiFi in the future or not, Some Bluetooth chipsets are also WiFi chipsets (most PCs and phones, for example), but thereās no guarantee, and a heck of a lot of software would be required to do that.
So the short answer is āMaybe? Who knows?ā followed by āAbleton Link, please?ā ![]()
If itās running embedded linux, then much fun could be had exploring the network stack.
Imagine being able to back up the tapes to your NAS (or computer) wirelessly, and copying samples and data to it.
Wireless backups would be great.
I played with it at SuperBooth. The screen is a concern. Itās just too dim, even in shade. The speaker is surprisingly great though. There is a passive bass port on left side. Makes a huge difference.
Is it worse then the OG?
The screen on OP-1 OG is one of the finest, IMO. At least from the gear I own, apart from the DJI CrystalSky screen that was conceived for a pro use under the sun.
I used OP-1 OG under daylight without any trouble.
It would seem that OP-1f screen is less strong, though, as far as I could judge from the videosā¦
But Iād love some firsthand report on this point as well.
IMHO, absolutely.
