I believe it was as bright as it could go? It just doesnāt appear to have much contrast.
It was outside, but under a tent in relative shade, and I still had to put my hand over it a lot.
Even then, viewing angles, to me at least, were not great. (Bear in mind it wasnāt a controlled environment!) But, it was something that instantly struck me nonetheless.
Regarding the speaker; yes, I think itās far more āusableā now. (But still⦠physics⦠etc)
However, itās not as much of a joke as the OG-OP1. It has some relatively decent bass response from the passive radiator on the side. You can feel it on a table, for example, and it sounded okay and loud enough, even with a lot of ambient noise. It was a very noticeable improvement. Drums may still be an issue.
Iād say you could jam in a field no problemā¦
The TE website indicates 256mb of āinternal memoryā, which I presume means RAM. The OG had 64mb.
Any insight as to the internal flash storage? The original had 512mb. Given the ability to store projects is basically 8x, Iād presume there is a spec jump there as well. Maybe 1GB or more?
Also, on the TE website, in the images showing the leather wrap, it shows the OP-1F has a cooling/fan vent on the side. This was not present in the original OP, and I suspect is a sign that this unit generates a lot more heat due to the increased power.
I caved and ordered one. Guess in about 45 days weāll see whatās up. Thatās a LONG time to wait. Not getting rid of my OG op-1 though. Still use it almost every day.
Iām not sure - I wasnāt thinking of listening in mono, just making one stereo track into two mono tracks to make extra tape tracks - similar to what you have in a DAW, some tracks are mono some stereo.
Personally Iām holding back my judgement on TE until they do or donāt release a FW update for the OGP1, containing whatever low hanging fruit from the Field list thatās possible given the hardware specs. For instance donāt tell me that āclick to holdā sequencer isnāt portable over.
If they do this, then to me thatās respecting the old unit as far as is possible. If they donāt, then they fully move into Apple-style āfuck you, dump that old version in the trash and buy the new unit if you want to playā territory. And at which point they can do one. After all, isnāt that kind of behaviour precisely why so many people avoid DAWs and the forced upgrade path?
Itās important to keep in mind that both hardware are completely different.
So they canāt just take a piece of code and put it on the other one.
If OP-1 OG still gets updates, it will mean TE chose to spoil their fan base, basically for free (or to show they far from despise their customers).
But I would expect OP-1f and maybe OP-Zf to be the center of their attention for the months comingā¦
Much crisper and seeing as the graphics sit right at the front of the screen now itās much more accessible as well. Brightness I would say is the same, but again with the screen being higher up then the OG it helps in that department as well.
Wow ! Thatās really interesting - I hadnt realised that - do you have any references?
(I had just made a naive assumption that they had used a later generation (but probably same family) of MCU, new DAC and peripheral ICs but that the microcode of the MCU would be similar and the higher level code would have been recompiled for the latest hardware! I had assumed this as a lot of the synthesiser models and UI were quite similar so had again assumed they had reused code. So I had thought that (if there was flash space) they could add some extra functionality to the OG one (from the field) if they wished.
But Iām sure you have more information or you woouldnt have been so explicit! Thatās really interesting ! Thanks for the inside info !
Hard to tell exactly where I got that, the pieces I gathered were mainly from Elektronauts and videos from SuperBooth22.
Thereās this post from ex-Elektron @Ess though:
This, and the fact that @ONE and other people explained the whole audio path was stereo + 32bits fixed point, from inputs sampling to synth/sample player engines and FX.
Whereas OP-1 OG was 16bits/mono.
So yeah, I am not sure weāll see OP-1f features on OP-1 OG.
