Operators, let’s get a thread going on MIDI stuff relating to the Z.
Having so much fun with this thing and I’ve got the Z playing nice with a few pieces of external gear using an iConnect Box for the MIDI hub. One feature I can’t seem to get working or even know if it’s supported is sending Step components to the midi notes? Anyone had any luck here?
the CCs and the setting channels is really straightforward, although I would like to be able to set the MIDI OUT channel without the app - which seems to be absent atm, Pretty cool the first time driving an analog filter with the little Z encoders!
@alexkehayias said:
So far connecting between the Z and 1 is in pretty broken:
crashes when syncing OP1 to opz if you press stop twice
opz iOS app with the two units connected crashes on Bluetooth connect
tempo between units syncs but is incorrect
switching to other tracks, all instruments are staccato or don’t work
connecting the units while on doesn’t work ( need to connect when off then turn on )
I couldn’t even get any notes to travel from the op-1 to the op-z; how do you set this up exactly? I’ve got midi in/out enabled on the z and op-1 automatically sends midi, so not sure what I’m missing…
maybe want to check the channel outs in the op-1 that match up on each track in the Z? (i believe shift+blue encoder in the COM CTRL menu)
That worked, thanks!
Hoping TE puts together a more comprehensive midi tutorial as more people get their hands on the op-Z.
Now that I can attach the op-1 as a keyboard, I’m finding I prefer just working solo on the op-z; it’s really fun for what it does. And although pattern sequencing is a different approach from traditional keys, it’s growing on me faster than expected.
Honestly the midi implementation the Op-1 hasn’t been all that impressive, seemed to have a mind of its own at times… I hope they do a better job with the Z, it is a sequencer after all. Oh I love both devices and don’t mind some extra sync / content procedures, as I believe having to choose content carefully lends to better production, but if I’m going to have issues with midi I want it to be a chain problem and not ghost notes and temp / pitch madness.
so i was thinking that my cirklon would nicely control op-z via MIDI. i bought apple usb c to digital av adapter. i thought that would do good midi and even able to charge op-z at the same time. However none of my assumption was possible. MIDI doesn’t work and it can’t charge op-z either… so what would be the best way to send MIDI in/out to op-z and charge it at the same time? i just burnt $69 on this adapter… I wish my octatrack was able to send midi over usb like digitakt…
@radar24 I know this won’t help with charging but have you been able to use a normal cable and get midi working without charging between the Cirklon and the opz?
@houtson what do you mean by a normal cable? i can’t connect op-z and cirklon directly and i need usb c to usb a converter so i thought apple adapter would work but it apparently not.
Once the first module is out there will be standard 5 pin midi (and CV) control in and out, you will then be able to control the OP-Z from any Midi device or send Midi to any Midi devie from the module track.
Just wondering if it’s possible to sync op-1 and op-z via a usb c to usb c cable, or a regular usb hub (like for expanding the amount of ports on a laptop)? Does anyone know if either of these would work?
@radar24 I was meaning with just a simple adaptor (one of the usb a-c for a couple of $) rather than the apple one - just to see if the midi works with the cirklon
