I bought a DJ controller and started mixing all the songs I have created with the OP-1, OP-Z, PO’s. If you got some time to kill - mixcloud.com/timebeam
Playing around with the OP-1 and an old copy of Reason…
Here’s a little jam I made this morning. Please Enjoy.
this time it’s our pleasure to introduce…
quick jam utilizing some samples from recent vinyl record acquisitions.
My first attempt at techno on OP-1:
Really good, one of my favourite OP-1 pieces. Could you offer a quick explanation of how you put it together?
Thanks man!
I’ll try my best for an explanation, though I started many months ago so I’m not sure I can completely remember. I think I started with those two synth lines that begin the track, probably both sequenced with endless and the FM engine. The drums were made with a patch that uses a random modulation on the CWO effect, which I recorded to the tape messing with the tape speed as I went to create pitch up and down effects. I then cut up the best bits of those drum recordings and resequenced them on the tape. I then reinforced those drums with more layers, which I then bounced all-together on to one tape track, trying to give them more punch through the master EQ and drive/compressor thing. After that I work on the arrangement and layered up the synth parts quite a bit. Finally, when playing through the track I had two different memorised EQ settings, one brighter and the other duller, which I swap between for the drop sections and builds.
Thanks a lot… what an effort! You really show the potential of the OP-1.
What is this?
messin around on the thing.
slowin it down on the thing.
getting moody and things
I guess the excellent track from the 12 operators collaboration belongs here
Thanks @blumquist for launching this project, and everyone involved for your awesome participation: I’m amazed at the result, especially the 11 transitions!
Much love for OP-1 and more generally music in such track, tells a lot about this community.
You guys okay if I get this on Small Ops? This is so dope…
Of course
messing around with the OP on summer vacation.
regarding above…
hoping to one day surpass the same number of tracks and posts @sammyjams has on this thread!
(slowly but surely)
